fork is coil and air in one leg and tst in the other, to remove you use a standard cassette tool to remove the top cap of the left hand leg, (remove the air from the valve first!) then remove the top cap and the spring is located directly under this. The coils are not available aftermarket (yet) and they only produce 1 weight, the standard one in all the forks.
Not sure I would run it with no coil and only air myself. I was faced with the reverse problem to you, wanted a heavier spring so could run less air, but this was not available. TF tuned and Windwave didn't really throw up any ideas and were pretty unhelpful. apparantly for the 2010 forks different spring rates may be available and these would be backwards compatable (I believe)
your only option is to put on some weight! or swap the fork!
