Anyone know of any resources for planning a 12v domestic lighting system.
I cant seem to find much about it online. I have the opportunity of wiring a barn conversion wholly for 12v LED lighting from a single supply point. In theory I can then drive the entire domestic lighting requirement from a combination of SLA batteries/microgeneration (PV, wind) and mains transformer/charger for back up/night-time Economy 7 charging.
Current transformer based systems demand very short cable runs (obviously due to the higher current and the skinny wires they supply), if one were to use thicker core cable would that prevent too much losses?
Some time ago I was planning a long run for a 12V system & a guy I spoke to [sorry can’t remember the co] told me that 10²mm cable was capable of 50m runs
I’d opt for a conventional wire in the house with localised LED transformers then handle all the CU end of the lighting circuit using some sort of battery driven UPS hooked into the mains for resilience.
Not knowing much about eletrickery I asked an electrician about this once. Seemed to me that given the large number of wall transformers and low voltage lighting in most houses it would be sensible for them to have a normal 240v ring and a secondary 12v ring (presumably with different plugs).
But he said the same thing about 12v not working on long cable lengths, so I guess unless your house is the size of a caravan it isn’t practical.
I’ve seen LED direct replacements and they’re WAYYYY below the nice even light distribution of a normal lamp, so it would take careful planning and knowledge of the fittings. The cable you need would depend entirely on the distances and the number of LEDs run, not really something that can be generalised but I would have thought it better to go with localised transformers – you can still go down the battery-power route using a good quality inverter without too many loses.
Planning layout and spec isnt a problem as we have a clean sheet and can make the most of defined good practice and industry experience without being forced to simply replace 240v units.
Actually a good quality inverter should perform near 90-95% efficiency and decent transformers should be around the same, leading to ~19% loss worst case, unless you buy cheap tat. However that would then require many transformers which is more costly than a single-point large transf. Swings and roundabouts.
looks like Ill need to get the calculator out and work out what the capital cost of the two appraoches would come to…one with more copper and less electronics, the other with less copper and more electronics…
but see its still very dark in that room monty, looks like a candle-light dinner rather than a house where you can live and do stuff with decent light. Same thing seems to be the case with LEDs, unless you wildly scatter them over everywhere with joyful abandon, its a dull and sharp.
We’ve completed major renovation work on our kitchen, and the whole lot is lit by LED lighting now.
Colour wise it’s virtually identical to halogen. It’s all 12V, and a mixture of LED downlights (equivalent to the halogen ones), and LED “ribbons”, which light the inside of cupboards and the work surfaces and so on.
Things we learned:
1. When hunting for the halogen replacements, do not get the ones that look like an array of normal LEDs. They’re useless and have a limited lifespan. Instead, we’re using ones which have a gridlike pattern of surface mount LEDs, which kick out more light than their halogen friends and have the right colour.
2. The LED ribbons come in a selection of colour temperatures. Make sure they all match. Ours look exactly like halogen light.
With regard to your plan, I would keep 240V as long as possible. Get a cheap inverter or something.
Actually a link to his LED tape supplier would be handy too 🙂
I think he is thinking of the luxeon/cree based LED lights, rather than standard 5mm body diodes, luxeons are multiple LEDs in one package, the same sort that go into the high-lumen output LED bike lights.
Posted 14 years ago
Viewing 26 posts - 1 through 26 (of 26 total)
The topic ‘Light a whole house with 12v system?’ is closed to new replies.
