If your leaking air / sealant at the valve / spoke holes then your rim strip is not working. A genuine stans rim strip is only about £12 quid and as long as you get the correct width it will work very well.
Have you put any cloth tape under the cut-off tube/strip or sealed the spoke holes with a layer of electricians tape as that will help retain air.
With regard to the tyre leaking air/sealant, some tyres just do not seat/seal easily. Is the bulldog easy to get onto the rim? When I have had a setup that works the tyre had been a bugger to get on the rim, requiring the use of metal tyre levers and a lot of force. This usually means it will seat quite easily. Tyres that are easy to get on the rim usually prove hard to seat or just do not seat.
You can try adding one or two layers of cloth rim tape under the tube / rim strip to make the tyre a tighter fit on the rim strip, and this usually gives a tighter seal on the rim strip allowing the tyre to seal more easily.
It is a lot of hassle to get setup, but stick with it as it’s a great system once you’ve figured out how to get it working.
