Before I get angry and throw £1k at a new frame, I really should try and fix the clicking I’m getting. So STW, can you help with the following symptoms and suggest a few things to try to fix it please? All the below is new ish, under 400 miles use anyway.
Set up:
Carbon road frame, PF86 BB, Ultegra cranks, Hope BB (newer, under 50 miles old), Ultegra SPD-SL pedals.
Symptoms:
Clicking noise on the down stroke when I press on the drive side pedal, it seems to be at about when the cranks are horizontal where I guess there is the most power going through them. I don’t think the noise is there when I press the non-drive side down
What I’ve tried:
New Hope BB fitted by a reputable LBS. This fixed a more general creak but not this click. I’m told the BB went in “really nicely” whatever that means.
Tightened the Rear axle and cassette up.
Re-greased the headset. The bearings are cartridge type and sit directly in the frame. They did come out a lot more easily than expected in that the simply dropped out of the frame. This is a possible cause though how I fix it I don’t know.
Cleaned and tightened bar and stem.
Cleaned, re-greased and reinstalled the cranks. I made sure the chainrings were tight at the same time.
Made sure the saddle was tightened up correctly though the rails are not greased or have any carbon grip on them (ti rails, alu fittings on a carbon post).
So what else should I try?
