My Whyte 901 circa 2012 developed a knock in the front end from the headset. I have removed the stem and forks and both cartridge bearings from the tapered headset, I was planning on ordering a new set of cartridge bearings to replace this set however am unsure what to order. The headset is the stock FSA orbit ZS (I presume this means zero stack), I am now thoroughly confused between integrated, aheadset, internal headset ect can anyone tell what sort I am running and if this impacts on what cartridge bearings I can use. Thanks in advance.
Note: I did take it to my LBS who confirmed it was the headset but declined to sort it out because “those monster MTB headsets are a pain”, so I think he must just have a roadie bias, hence having a go myself.
