Ok, I bought a big pile of painting kit, nearly all hammerite branded, so should have been fine, surely?
Striped the frame with nitromors
Roughed it up with a wire brush attachment
Painted it with hammerite rust eater (the white to black stuff)
Painted it with 3 coats of hammerite primer, sanded betwen coats, wiped down with a damp cloth, threads cleaned with white spirit to prevent buildup.
Put the topcoat on (more hammerite) and it wouldn't stick! I tried thinning it with WS, I tried sanding it down again, I tried everything, but hammerite wont stick to hammerite primer! It just wont go on, the thinner coats just shrink back, and the thiocker ones just go blotchy and run off. What have I done wrong? Has the primer somehow absorbed enough water to repel the top coat?
Next time I'm rattle caning it and stuff the several weekends of carefull preperation!
