Since getting Stans Crest rims I’ve had no regrets at all, so far have used Bonty Mud-x, Schwalbe Nobby Nic and now On One Smorgasbord.
Had a little trouble getting the Smorgs sealed when I first got them so ran them with tubes for a couple of month, hedge triming ment that I had 3 punctures in two days (no punctures for over a year before that when tubeless) so last night I had another go.
Bearing in mind the tyres already have thorn holes in them I was a little sceptical that I would be sucessful.
However with a bit of soapy water up they went, bang bang the beads went into the rim with only a few bubbles blowing from the holes.
Pressure released and then a scoop of stans sealant in each. Pumped back up, lovely job.
Except I’d put one tyre on the wrong way around, no problem, let out air, pop off rim, carefully pull tyre off the wheel, swap round, back on rim, pump back up again.
250g saved.
What the **** is there not to like?
