I have put up with the noise for 4 rides and after 8 hours of ignoring it I have had enough.
My EX8 has done 650 miles and is spotlessly clean, gets treated like a princess and never gets pressure washed. Over the last 4 rides it has started to make a creaking/cracking noise. At first I thought it was the rear shock pivot and bushings going dry but no they are fine.
I then thought it was the rear swing arm bearings but after removing the rear shock and then moving the rear up and down the noise does not seem to be there.
When I put the shock back on it starts again.
It appears to be the gear cable ferrules in there mounts on the frame only clicking when the frame makes a certain movement.
I have cleaned, degreased and re-lubricated the outer of the ferrules without removing them (takes a while to remove and re thread the rear gear cable) but they are still making the noise.
Is this a simple case of ripping them out and fitting new outers with ferrules? Or does anyone have a trick I can use?
I am now starting to wonder if it could be the RP2?
