Garmin Edge 705 kee...
[Closed] Garmin Edge 705 keeps turning itself off! Help?
Pretty much as the tile. It seems to happen most often within a few mins of first turning it on, but can happen at any time.
Did a ride tonight, about an hour and it happened 3 times!
Battery is fine and pretty full charge and I am sure I have not pressed the button by mistake
Has anyone else had the same problem? Is there a fix?
Thanks!
Posted : 08/05/2013 9:36 pm
its the USB port rubber getting squashed - this connects the battery to the unit.
you need to split it - and youll see the rubber round the USB port - cut another out of an innertube and fit the two - this will provide a constant contact.
Posted : 08/05/2013 9:39 pm
Does it make any difference that I have lost the rubber blanking piece to cover the USB port?
Posted : 08/05/2013 9:43 pm
nope
its the act of pushing the usb in when you get to the computer
my 205 was the same , worked fine after the above fix TILL i dropped it shutting the garage door and smashed the screen.
its a common fault
Posted : 08/05/2013 9:44 pm
 stex
Just tried this on my 705 that died a few month ago, garmin said it was goosed and would exchange for £100.. It now works fine...cheers Trail rat .... 8)
Posted : 08/05/2013 10:28 pm
fyi a little clear silicone works for sticking the 2 halfs together - just use zip ties to hold it till it sets
Posted : 09/05/2013 6:20 am
