Rob and the Captain are rarely less than enthusiastic about guitars, they’re taken from stock and they really don’t want to be stuck with something they’ve slagged off.
That doesn’t mean their reviews aren’t useful but they do make light of some of the failings of some guitars – note I haven’t said cheaper guitars. I’m quite familiar with Teles and Strats and in a blind test I’m absolutely certain I’d be pointing out big differences that they gloss over that are sometimes very much in favour of the cheaper guitar:
I’ve got two Squier 50s Classic vibe necks from 2012 with close serial numbers. They are quite the most comfortable gloss finished necks I’ve ever put my hand around. Running a hand down, the frets are perfectly finished and the edge of the neck is nicely rounded off so it doesn’t dig into your thumb, the frets are high enough without being so high they cause intonation issues if you press too hard on the first frets. Nut adjustment is perfect out of the box.
None of the American Teles I’ve played have had such well finished frets and the frets on the American Special in particular are high enough to make chords in the first three frets sound sharp if you press too hard.
Anyhow, back to the OP’s question. I’ve played a Squier 3/4 Strat and it felt very good, better than the American Special. I didn’t plug it in so no comment on the pickups. If you go full size a Squier Classic Vibe Tele or Strat will hold its value better than the Yamaha Pacifica which would be my second choice, or fist choice if you buy second-hand.
