we did work on crts when i learnt digital electronics and fixed some faults, hmm that pic looks familiar.
i actualy dont even know if crt tech is same as lcd for the frame side of things but on crt they used to be a frame chip that commonly caused issues like in the pic and sometimes some capacitors around it used to go out of tollerance and were visably defective. sometimes it was just the solder joints around the capacitors causing the issues.
i would do exactly what seo says and hit it and see if the picture changes or momentarily returns, if it does, its most likley a dry solder joint somehwere.
not much help i guess but be warned that tvs can hold charges and give you a decent shock even when powered off, when on they can kill you.
