Theres two bedside wall mounted lights in my kids bedroom. They are switched at the light itself wuth a pull cord but theres a wall mounted fuse plate thing as well.
I’ve removed the fuses to both of these lights so they don’t have any electrical hazard at the moment, but my kids keep playing with the light fitting itself, pulling the cord all the time. also theres a glass shade on it so not safe if they smash that.
So I’d like to remove these from the wall. When I unscrew them theres just a little bracket they attach to and a connector block to attach to the cable coming out the wall.
If I take them off how do I blank the cable off as theres not a back box like you would have on a plug socket?
Or is it just a case of getting some kind of connector to cover the wire ends and shove the wire back in the wall then plaster over? If so what connector do I look for.
Fuses to the lights are removed at the separate wall plate (about a metre away by the bedside sockets) so they aren’t live anymore, just want to prevent them playing with the light fitting at the moment.
I’d like the option of being able to refit the lights at some point when they get older.
