Hello all,
Currently installing a cane creek spring on a DHX 5. The fox manual says to turn the preload collar until there is no movement in the spring (or the spring is snug), which is fine, however because the internal diameter of the cane creek spring is slightly larger it’s difficult to tell when the spring is engaged due to lateral movement.
So I’m wondering if anyone has experience of fitting cane creek springs to DHX shocks? When setting the preload should I work from when the spring has no movement along the line of travel or when there is no lateral movement? As fox are quite specific about the max turns of the preload collar I don’t want to risk damage by over tightening it.
Thanks
Murray
