Hi Onzadog
I have some good experience with “alternative” road setups although the highest pressure I’ve tried was only 65 PSI with various 700c 32-35mm kevlar bead tyres, mostly Schwalbe Kojaks 35mm and Rivendell Jack Browns 33.33333mm, on Stans ZTR355 29er rims. I found that at this width 50-60PSI seems to be the best compromise between speed and comfort.
The funny thing is… after having done some runs with various tyres I found that 25mm GP4000s (tubes, 100PSI) eren’t significantly faster than Jack Browns (if any, more testing needed).
I’d bet you could put some 25mm (eff. 29mm on Stans rims) Contis on and pump them up to 80PSI. All you need to find out how far you can go is a camera and a compressor. Turn on the compresor, leave the camera on in a video mode and… go for a walk or make yourself a cup of tea.
When you come back, you’ll know what pressure it went to and you’ll have a funny clip to post on Youtube 😆
