So my Smart has an active crossover and runs the rear channels to dash mounted tweeters. These have a 10mm voice coil and a cap in series to give a crossover of 9khz. I’m told a subwoofer helps a lot and running a hifi speaker as one, off the bass feed (with cobbled together crossover) certainly helps.
My Qs:
1. A larger tweeter should help? The midband sounds a bit poo.
2. Are these active subs any good? Size of A4 paper and 4″ thick. Can they really chuck out as much good bass as a 10L bass reflex? Buying proper crossover components and making my sub will cost more than buying one?
3. If you use these active subs, do you just “turn the bass down” on the mid driver?
