Is there a away to change the orientation of the cassette joint on a 8 speed Alfine?
I’ve tried switching around the anti-turn washers to change it but I can’t get it to lay along the chain stay, it want’s to be inline with the seat stays.
I didn’t know if it’s the way it has been put together and if I took some of the gubbins off I could change the orientation?
[url=https://flic.kr/p/GQuz4h]IMG_20160505_175605[/url] by Stephen Williams, on Flickr
Well I found out why I’m having a issue…… my good LBS…… has installed a 11speed cassette joint onto an 8 speed Alfine… no wonder I can’t get all the gears! 😡
So I’ve had the bike back a couple of weeks now, the LBS fitted the proper part all free of charge and finally got out to give it a run!
Have to say it’s like night and day with it all working as it should, I was beginning to think I made a mistake going Alfine but am pretty confident with my decision now…. just need to build my legs up again.. maybe a singlespeed wheel for those days I wan’t a harder ride….
[url=https://flic.kr/p/M7de8P]14188134_10153872872863225_1069897283868561573_o[/url] by Stephen Williams, on Flickr
Also enjoying the Carbon Alt bars in the form of the On-One OG bars provided by Jossie on here! so much so I’ve decided not to change my frame atm while it’s still so nice to ride, next time I damage my rims I might try 27.5+ in it but atm happy as is, a tad newer XT brakes has helped…. M765 to M785.
[url=https://flic.kr/p/M4bGdy]14212807_10153898624718225_5206254317153832326_n[/url] by Stephen Williams, on Flickr
Just put my alfine in for a new rear wheel and bits – it got jet washed about 4 years ago and the now undergreased cup and cones have pitted and after 7 years the shifting has gone to pot (dunno why).
Saccaredes – have you serviced it at all? ie oil dunk te internals? If not the sliding mechanism for shifting gets gunked up with old dried out grease – also play in the bearings can affect shifting.
Serviced 😆 The whole bike has only been washed 6x – it normally looks like this:
Forks have changed from RC41F to RC40xcam
Edit to say – That photo was taken last year and only the fork and seatpost/seat has been changed (excluding consumables), think I’ve wrung value for money from it.
