What have you got behind your stove for heat proofing? I've got a modern house, stove is going to be freestanding (no chimney or fireplace) against a plasterboard wall so will either need a slate/stone back or heatproof board. I've got (hetas approved) fitter lined up but lacking inspiration for what to do behind...
I usually chop out the plasterdoard about 1200 square and brick on edge behind. Dab fireline plasterboard onto this to give a 75mm thick non combustible layer.
If it's a party wall rather than external, then just chop out any woodwork and replace with metal studding then fireline plasterboard on top.
Some stoves will scorch the wall finish behind so tiles may still be required anyway.
I used fireproof plasterboard.
http://shop.vitcas.com/vitcas-high-temperature-plasterboard-709-p.asp
External wall - plasterboard onto wood studwork (I think!). Chap who came round earlier suggested that heat resistant board was a different finish to plasterboard and couldn't be skimmed over (that bit makes sense) so it was always going to stand out as an inlaid section on the rest of the wall - is that true?
Not quite the look I'm going for, but how would you achieve this kinda thing??
looking at that link PePPeR, looks like I need to find a fitter who knows what he's talking about!! Sounds like you can skim ok with the right plaster and guessing you could blend that in with the rest of the wall ok and then re-paint the whole wall. What stops the paint scorching?
we had fireboard put behind ours then some kind of plaster skimmed over that resists cracking with heat(i think, it may be normal plaster for all i know!)? but, for all the precautions even when the stove has been on all day the plasterboard behind the stove (and to the sides)is cool to the touch.
during installation
[img]
[/img]
front room inset
[img]
[/img]
5mm Heat soaked glass.
I'm probably the last person you should take advice from as none of my stoves have been professionally installed or certified
This one I installed following the manufacturers instructions. They required a 200mm gap between the rear of the stove and the wall. There is still some heat transfer but nothing to worry about.
The other two stoves we have radiate little or no heat to the rear.
Do you find the free standing ones produce heat more efficiently than the inset one Carl?
Cheers for your thoughts - just had a look at the tech spec on the Morso stove I fancy and it reckons 600mm clearance at rear to combustables (not a dedicated freestanding stove - they have much lower clearances of 150-200mm) so that's not gonna work. So looks like skimmed fireboard inlaid...
That floor does look gorgeous mcmoonter!
We have both and the freestanding stove produces more heat more quickly. But, although it's a bit slower to heat the room, the inset stove puts a lot of heat into the brickwork and this radiates heat for a day or two after the stove has gone out - it's a rather nice effect really.
[i]Cheers for your thoughts - just had a look at the tech spec on the Morso stove I fancy and it reckons 600mm clearance at rear to combustables (not a dedicated freestanding stove - they have much lower clearances of 150-200mm) so that's not gonna work. So looks like skimmed fireboard inlaid... [/i]
300mm on ours.
http://www.storesdirect.co.uk/stoves/stovax-riva-f66-freestanding-multifuel-woodburning-stove.html
Gloss varnish? Oh dear.
Nice room though.
