Struggling to fit them on the XTR pod as I think you've got to undo the allen key bolt, which should release the clamp but then there's another screw which you can only get too if you open up the pod, when I opened the pod to get to the screw I've knackered the springs and can't get it back together, so I've got a new one on its way but don't want to knacker that up. Has anyone fitted these before?
Isn't that something to do with bikes? Be away with you, you fool!
RTFI that were in with the clamps?
there were no FI in the pack
I feel your pain. I stuggled for ages before I realised you had to open the pod and remove the little screw on the back of the stardard clamp. Once you remove the hex bolt on the top it moves quite freely (it has to allow the sideways adjustment but keep the shifter falling off the clamp), which led me to believe it just needed some 'wiggling'. After 15 mins of 'wiggling' I looked it up on the web to get help. Should defo have some instructions. Luckily my shifter did not explode in the process!
Hope you get it sorted.
