Does the camera have voice activation? With my samsung i say SHOOT and it takes a picture.
With the dual sim ,if I'm in an area where O2 doesn't get a signal will it swap over to the other sim if that gets a signal automatically , or is it more complicated than that?
Morning bump
I cant see anything in camera settings about voice activation
I'll see if I can find anything in the manual
it says this on their website-
Two 4G networks cannot be used simultaneously.
When using two SIM cards, 4G support is only available for one card at a time.
manual-
Can you tap anywhere on the screen to take a photo?
You could install a better camera app. Try Open Camera.
There is a setting in the camera app for this, tap to focus then tap again to take the picture.
Think the voice activation will be a Samsung customisation, might be wrong but havent seen any reference to this on my A2 lite.
Regards the sims again I could be wrong but I think you have to switch manually between them in the settings, only takes a few seconds so not a biggie.
with the dual sim, you will always recieve calls from both of them providing you have signal. When you make a call, you choose which sim to make the call from, you can only use data from one sim at a time, one has to selected as 3G, if one of your sims is on the Three network then that has to be the data sim if you also want to make and recieve calls on it since they only have 3G/4G network
Ill put the google camera on it soon
One problem I have is it making calls etc in my pocket.Probably cos I got fed up with having to unlock it every few seconds so iirc I adjusted the lock screen timing and now I cant find the setting to change it again, Im not much good with these things.
