woodchip arrragghhh
[Closed] woodchip arrragghhh
 DT78
I have 2 large rooms to strip. it is taking forever. have a new steamer on order.
even once it's mostly removed there is still some brown paper residue which only seems to come off with a razor. this will take longer than I have left to live
the wall feels smooth to touch. could I just paint over it and it will be okay? would a primer do it followed by emulsion?
Posted : 05/10/2019 4:47 pm
Soak the wall see how slimy it gets.
Paint doesn't like it.
I skipped the problem by pulling the embossed wall paper at an edge and it bringing all the plaster down with it.
Or... Just get it skimmed.
Posted : 05/10/2019 5:43 pm
I got mine off with the steamer, the underlying plaster got pretty damaged. However it all looks ace after using that polycell smooth over stuff, super easy to put on and finish. Painted straight on to that, really easy to make it look good.
I tried a b and q cheap version of it, that was pants.
Posted : 05/10/2019 6:15 pm
Last time I done it I criss crossed the paper with a Stanley Knife to help the moisture get in.
Posted : 05/10/2019 6:18 pm
also this^^^ worked well
Posted : 05/10/2019 6:40 pm
Once you have all the existing paper off the walls, you have a few options:
Wash walls with dilute sugar soap and rinse with clean water before painting or wallpapering
Or
Hang lining paper before painting or wall papering
Or
Re-skim with finish plaster and then paint or paper to desired finish.
Scoring the existing paper before steaming or soaking will assist greatly but woodchip is an arse to remove. Enjoy the process as much as you can, it’s not all about the destination! 😉
Posted : 05/10/2019 6:45 pm
I used some stuff called DIF wallpaper stripper after scoring the walls/paper. Came off easier than with just a steamer.
Posted : 05/10/2019 7:02 pm
Proper paper stripper has a 4 inch Stanley blade. Really good for moist woodchip.
Whenever I’ve stripped it, I turn the room into a sauna and do I it in my pants. 👍
+1 for the scoring.
Posted : 05/10/2019 8:13 pm
You may need to skim the wall anyway - the main reason people put woodchip on is to hide the bumps in the wall.
Posted : 05/10/2019 8:15 pm
We have the perfect tool at work for stripping woodchip.
It’s called a 1st year apprentice painter.
Posted : 05/10/2019 8:54 pm
Life's too short for that shit I went nuclear on the woodchip on the stairs
Insulated plasterboard and taped/skimmed/painted. Bosh.
Posted : 05/10/2019 8:56 pm
buy a spiked roller
roller every wall and ceiling. spray with water with cheap hand sprayer
buy a decent paper scraper not the shitty spatcheler type the one with the blade. just done 2 rooms not that bad really never used a steamer..
Posted : 05/10/2019 9:24 pm
As above- stip down to your pants and make a sauna of the room. Spiked roller, find a decent scraper that you find comfortable- you are going to be holding it for a while! I find that scrapers are a bit like fountain pens- they sort of become worn/ matched to you. When I moved in to this place every wall and every ceiling was covered with layers of paper, polystyrene, woodchip and gloss paint, in a multitude of configurations. All on top of lath and plaster.
The electrics tripped more than a couple of times, I think due to the high humidity in the room.
Posted : 05/10/2019 10:20 pm
This fella is called Woodchip!
https://imgur.com/a/K6zBLon
Posted : 05/10/2019 10:51 pm
don't buy a cheap roller scorer thing. The serrated scoring wheels come out of their fixings and you then run your wrist over it.
Don't ask me how I know.
Also don't ask me how I know that blood soaks into steamed woodchip really well.
Posted : 05/10/2019 11:01 pm
Hello I just stripped a medium sized house with tons of woodchip. I fried a steamer on the way but here’s what worked for me:
https://www.screwfix.com/p/heavy-duty-scraper-4/16530
With a steamer, and importantly one of these medieval weapons to make the steam penetrate:
https://www.toolstation.com/prep-wallpaper-perforator/
All stripped quite quick after a few practice walls.
Posted : 06/10/2019 9:14 am
I just realised I did not answer the question. Lol. Good luck
Posted : 06/10/2019 9:15 am
