why is there water ...
[Closed] why is there water in my loft?
Went up there today to do some DIY and noticed a large number of drips along one side. The insulation is about 200-225 deep with loft boards on top. I've been careful to keep the insulation away from the edges so the loft can breath and I added a vented ridge tile to suplement the original one when we insulated and boarded.
The bottom two rows of bitumen felt we're damp to the touch on one side.
Is is
1 knackered felt, leaky roof.
2 sweating due to a lack of air flow.
3 because I went up there and the hatch was open, I let warm moist air from the house up there which condensed on the frosty roof.
Please tell me it's 3, 2 at a push. Just don't tell me its 1. By the way, it was built mid 1980s, typical Barrett/wimpy affair.
Posted : 02/12/2012 9:44 pm
number 3
I've just been up to get the decs down.. same sort of deal.. little raindrops everywhere..
Posted : 02/12/2012 9:49 pm
Go back up mid day on a not so cold day and recheck. Check the timbers for moisture. If it was a leaky roof it'd be more isolated and making its way rheo the ceilings. Condensation isn't one to be ignored tho. Personally I dont like the idea of over insulating older roof spaces as I think it causes more problems than its worth..
Posted : 02/12/2012 10:15 pm
Cold roof filed with warm moist air from inside the house, condensed onto the roof as it met the cold surface perhaps?
Posted : 02/12/2012 10:21 pm
4) vampire bat piss, obviously
Posted : 02/12/2012 10:25 pm
 poly
I get condensation on the nails that stick through the boards. It happens on cold dry days, but warm wet days its bone dry up there.
Posted : 02/12/2012 10:41 pm
No evidence of old drips up there. Seems to have only started on the day I went up there.
Fingers crossed that it was just that.
Posted : 02/12/2012 11:11 pm
Condensation. How do you know it's not happening on the days you don't go up there? Vent your house more, leave window trickle vents open / ajar, keep heating on. Oh, insulate the topside of loft hatch too.
Posted : 02/12/2012 11:35 pm
Can you feel any airflow in the loft? Check the vents on the soffit boards - mine were clogged with years of muck. Brushed them clean, I could then feel air moving and condensation went away.
Posted : 02/12/2012 11:42 pm
