Which Combi Boiler
[Closed] Which Combi Boiler
Nothing wrong with the boiler.
Whatever way they’re running the scheme we’ve been told that they need to meet some energy efficiency saving to qualify. They can achieve this by replacing a boiler that more than 8 years old and adding underfloor insulation (I think this is a fiddle to be honest – I reckon at best a new boiler will be a couple of percent more efficient than our current one).
Our boiler is 9 years old. We’ve been intending to do underfloor insulation in the house for a couple of years but never gotten around to it. We were expecting it to cost around £300. We’ve been told £500 for boiler + insulation. Seems a no brainer.
Is this the new green homes grant?
I've got an ideal fitted about 5 years ago, been no issues. Just fitted a new boiler to my house and went for a Baxi 830 (same unit as a 630 just 10 years warranty rather than 7).
Several installers i talked to told me Worcester Bosch are a pain to service so they can never be arsed to do it properly (have to take a lot of it apart to access certain parts). Not sure if this is BS or not.
Went for the Baxi because seemed a couple of hundred quid cheaper
Posted : 17/12/2020 10:33 pm
I've got an ideal fitted about 5 years ago, been no issues. Just fitted a new boiler to my new house and went for a Baxi 830 (same unit as a 630 just 10 years warranty rather than 7).
Went for the Baxi because seemed a couple of hundred quid cheaper than the equivilent WB.
However not that convinced yet as the running costs seem higher (but thats a seperate thread)
Posted : 17/12/2020 10:35 pm
10 years servicing for a warranty (limited?)
Fair point I suppose, but as said, the manufacturer doesn't directly financially benefit and they all insist on it to maintain the guarantee. So hey ho. I pay £50 cash in hand every year for the installers signature on a guarantee, If you want to look at it in that way.
Posted : 18/12/2020 12:59 am
 Del
swings and r'bouts. one advantage of getting the services done is you've got a plumber on the end of the phone if you need one and the back up of the manufacturer's warranty. if you get a problem and the manufacturer can't fix it you'll get a new boiler. if something else goes awry you've got your plumber you've been feeding regular work to. i've lived in a house for 2 weeks in a cold november without heating or hot water because i was trying to do things on the cheap. i'm in no hurry to repeat the experience.
Posted : 19/12/2020 12:44 pm
Ideal logic in my radio rental. Been faultless since install
Outside air temp thingy boosts output when its cold outside apparently
Get a service anf gas safe cert by law annually so keeping up the warrenty is simple and ties in
Own flat WB 24i. Old maybe 15 years and has issues, low voltage relay fsiled. New pcb wss spendy so by sheer luck found the part on ebay for 25p and soldered it in myself
Fan bearing failed, wsd an issue and is common so acquired a spare off ebay for £10. Fitting screws rusted to buggery so hole sawed round them then cut same holes in new fan, self tappers and silicone sealant and its working. Reverbs a little on start up mind
If it fails again its probably goingbto mean a new boiler as the fan will not be easy to remove
Posted : 19/12/2020 2:29 pm
Page 2 / 2
