What was the last t...
What was the last thing you bodged - must have actually worked?
After getting repeatedly outclassed on the What was the last thing you MADE thread, I thought I would try one closer to my skill level.
So what have you made / done to get a job done which might not have been orthodox, used the correct equipment or even been vaguely safe but it succeeded in getting the job done?
The only rule is that it must have worked for long enough to actually get the job done.
I will start with my custom alloy vacuum extension to get the dust out from inside the table saw through holes too small for the vacuum pipes I had.
Posted : 19/05/2022 10:53 pm
Needed to do some tilling around my rebuilt fireplace
Could i find my notched tile adhesive spreader?
Nope
But i did find a big ring of a compact chainset.
Ok so it wasn't quite as good, but it did the job over a slightly narrower area
Tiles are still on the wall. So it must have worked.
Posted : 19/05/2022 11:01 pm
 irc
A linkage broke in the flush mechanism of our toilet. Bodged a repair using thermosetting plastic granules to give something for a small screw to bite into. Still eorking a few years later.
Posted : 19/05/2022 11:09 pm
Er
The list is long. I've so many temporary fixes still going strong I'm bit sure what's the last.
Posted : 19/05/2022 11:11 pm
Bicycle puncture patch to fix a split in a washing machine door seal. Was only suppose to hold till the new seal came. New seal remains unfitted since January. 😁
Posted : 19/05/2022 11:35 pm
I made the one-way valve on my packraft actually one-way with the careful application of a slice of dish sponge. Works a treat.
Posted : 19/05/2022 11:40 pm
Inside cage plate of my XT mech inexplicably snapped on a ride a while back. No impact, no idea how or why.
So I glued it, made a thin steel plate, then pop riveted it. Works fine*
*it was working fine before I noticed it had broken, actually.
Posted : 19/05/2022 11:44 pm
Two spring to mind.
1. Our last washing machine had a hole in the drum housing, I suspect a screw left in a pocket exited at high velocity.
Rather than strip it down and replace/repair I cut a hole in the side of it and patched the damage with fibreglass.
Pushed under the counter the hole was invisible and it ran for years.
2. The bog flush button broke around ten years ago.
I made a temporary new button from a stem top cap glued into the back of a Porsche headlight switch.
It fitted perfectly and is still there.
Added bonus, you can adjust the size of flush by turning the light switch.
 dti
Hole in a stainless steel sink caused by an over zealous knife - blob of black sticks like shit - lasted for months - that stuff is amazing. The builders baler twine.
Posted : 20/05/2022 8:51 am
Blocked the toilet last weekend. Hot water / washing up liquid not working, no black bags left in the house. DIY plumber snake out of old gear cable outer did the trick!
Posted : 20/05/2022 1:09 pm
Had to dismantle the washing machine, removing the rubber boot thing from the sump. It was held on with a special jubilee clip thing that point blank refused to go back on (suspect you need a special tool).
Normal jubilee clip leaked because pressure wasn't applied evenly to the rubber. "Fixed" it "temporarily" with a wee roll of inner tube in the weak spot which then kept going for the next few years until terminal bearing collapse wrote the machine off.
Posted : 20/05/2022 10:24 pm
This is basically how I run my life - I don’t think I’ve ever fixed anything ‘properly’. Recently I’ve:
Fixed a mudguard with a couple of washers and some superglue
Cut up an old inner tube to replace rubber ‘feet’ on a speaker
Used a toy plastic cup to replace a door/seal on a washing machine
Used a 5 pence peace inside a shower hose to stop water coming through, as something is leaking somewhere. The hose has to be unscrewed and the coin removed each time a shower is needed, then replaced when the shower is over.
Posted : 20/05/2022 11:11 pm
Washing machines and toilets seem to be the most common bodge fix.
Posted : 20/05/2022 11:18 pm
Ooh loads of car ones. Hmm, back window popped out when I was moving a fridge for a mate. Bit of bathroom sealant, jobs a good un, Just had to remember not to drive fast with the windows open.
Posted : 20/05/2022 11:33 pm
Brum Uni minibus loaded with the bike club dropped its exhaust on the floor going up Bristol road on the way to a BUSA event. Bodged it with a can of beans and some index cable I had in my toolbox. Lasted the whole weekend.
Pulled the same trick with a mates car in Innerleithen car park. Except we didn’t have a can of beans. Quick rummage in the bushes and found a dumped tennants can to bodge it with. Survived all the way back to Bristol.
You can bodge loads of things around the house with p38 filler.
Posted : 21/05/2022 12:18 am
The plastic cage(?) that holds your head on my Propero commuting helmet got broken somehow, meaning that it wouldn’t tighten or stay in place. I like that helmet, it’s great for commuting.
I narrowed down my stickiest duct tape to hold the broken end in place and then clamped the tape down with heat shrink. That was six months ago. It is still in place.
I really should buy a new helmet though, but that one is just perfect for the job.
Posted : 21/05/2022 5:09 am
Day before our holiday the shop toilet stopped flushing. The plastic push diaphragm had perished.
Cut a plastic milk bottle to shape and 2 years later still flushing perfectly.
Posted : 21/05/2022 8:55 am
Repaired a crack in a water butt with a plastic milk bottle and a heat gun
Posted : 21/05/2022 2:02 pm
https://failblog.cheezburger.com/thereifixedit
Posted : 21/05/2022 2:16 pm
Turns out that my old ice axe pick is just thin enough to get weeds out of the drive gets some funny looks mind
Posted : 21/05/2022 5:38 pm
that's not a bodge that's hdpe welding, a legitimate repair using sustainably sourced filler.
Posted : 21/05/2022 6:12 pm
at work, the fan blade came off.
it wasnt replaced the next day so I found the nut that holds it on had broken
Its a left hand thread insert set in plastic so we dont have anything like that, but the industrial glue stuck the plastic back together in 5 minutes
much better now
Posted : 22/05/2022 11:54 am
so the new carpet and underlay meant that the door would not open without a big push
the new cordless angle grinder came out and sliced 10mm off the bottom of the door
no problem now
Posted : 22/05/2022 3:04 pm
[url= https://i.postimg.cc/bGdcHCVS/20220521-121337.jp g" target="_blank">https://i.postimg.cc/bGdcHCVS/20220521-121337.jp g"/> [/img][/url]
Not my bodge but christ
Posted : 22/05/2022 8:48 pm
That reminds me of the mains pressure cold pip[e I found under the floor boards a couple of houses back. It had been blocked off when a downstairs toilet and sink were removed.
I say blocked, there was a sparkplug hammered into the end of the pipe and then the pipe bent into a sort of spiral so the kinks stopped the flow I guess.
Posted : 22/05/2022 11:14 pm
That reminds me of the mains pressure cold pip[e...
...that was stoppered with a wine cork and pvc tape. They'd moved out and needed the washing machine so it was easy to see; where's the removal box with the plumbing kit in?
Posted : 23/05/2022 6:59 am
Hot shower
Not my bodge, but this was the shower in a place we stayed in on our honeymoon. Heater element in the shower head, complete with exposed mains connection... I wonder if the galv water pipe is the earth, or the water running over you while you shower.
Posted : 23/05/2022 9:25 am
Fairly common ‘life-hack’:
Magnets on either side of a shower curtain. Allows you to attach the shower curtain to something metallic, thus avoiding the inexorable inward creep of said shower curtain.
Posted : 23/05/2022 9:43 am
If it makes you feel better, there isn't actually a heater element as such in that shower-head. It just passes electricity directly through the water and relies on its own resistance to heat it up.
Never sure whether the people who install these shower heads are just ignorant of the risks, or are aware of them and lazy/sociopathic.
Posted : 23/05/2022 10:32 am
that’s not a bodge that’s hdpe welding, a legitimate repair using sustainably sourced filler.
That sounds like the words of a man who is used to justifying his bodges as proper repairs by using technical sounding words. Or a salesman by profession?
Posted : 23/05/2022 12:11 pm
Most used bodge item in my garage is the garden sprayer - used to mount tubeless tyres, pressurise the solar thermal system, had a shower head/brush attached to provide dog washing facilities, pressurise buoyancy tanks in my dinghies to detect leaks and....oh yeah..... spray weeds.
edit: Also sprayed the garden fence with it.
Posted : 23/05/2022 12:23 pm
Those shower heads are pretty common in South America/Brazil. Came across loads when I was over there.
Posted : 23/05/2022 5:52 pm
Does using a strap wrench to fit a BB count? Shimano in their infinite wisdom changed the cups so my old BB tool didn't fit.
Posted : 23/05/2022 5:55 pm
Those South American showers often had a rubber mat on the floor as well, which I told myself was saving my life. The only control of the heat you had was the amount you turned on the tap. The choice was a decent shower with cold water or a warm dribble with chance of instant death.
Posted : 23/05/2022 11:39 pm
Managed to use part of the ink pipe from a biro pen to hold my brake lever and the return spring together. To my amazement it lasted 150km over the weekend!
Posted : 24/05/2022 12:16 pm
Had a rack on the back of a road bike, used to have it on the back of a 26" hardtail for commuting. Unfortunately it didn't fit my current 26" hybrid I use for commuting. The probability seemed high that it could be fitted backwards so I did this:
IMG-20220523-174823
I've since taken the angle grinder to it and cut/ground more away. It fits very nicely now, albeit in reverse and with less support for panniers (which I don't have). Functions perfectly for my drybag of work clothes however.
Posted : 24/05/2022 10:46 pm
 bruk
Changed the car so new roof bars needed. Went with Yakima rather than Thule. Now the roof box won’t fit as the u clamps aren’t wide enough. grrr.
Off to the internet and someone saying Thule t track adaptors will fit my Halfords roof box. Ordered and arrived 2 days before due to go on holiday. However the interior clamps don’t fit.
Quickly dismantled the old u clamp interior part, drilled out some plastic widget to shim the hole and some washers and it’s on. Survived the test run down the long bit of country road nearby and then all the way up past Inverness and back sticking solidly to the roof and never loosened in the multiple times I checked it.
Posted : 08/06/2022 12:56 am
My tumble drier currently only works with judicial use of a sash clamp placed just right to lift the door enought to satisfy the latch sensor.
Posted : 08/06/2022 1:24 am
I have a selection of these
Posted : 08/06/2022 9:03 am
Boiler flue with sticky back foil.
Our old floor standing boiler's flue is impossible to buy as a part new or 2nd hand and the bottom of the inner section had rotted away leaving a 3” gap for exhaust and intake to mix. Engineer wanted to condemn it.
2 hours bridging the gap with layers of sticky back foil and all is well again. £10 vs £2k for a new boiler 😎
Posted : 08/06/2022 11:54 am
Washing machine seal held on with a selection of zip ties. Seems fine.
Posted : 08/06/2022 12:03 pm
Lack of somewhere to put a water bottle in my car (Citroen Berlingo) has bugged me for the whole 2 years I've had it. Door pocket kinda works but not great.
Recently realised that there is a standard for holding a water bottle used the world over (AFAIK)... On bikes. Thus, found a suitable location and screwed a bottle cage on with a couple of self tappers. Job jobbed. Would have used rivnuts if I'd had any the right size - might replace if I can be arsed.
Pic will not upload the right way up whatever I do 🙄 Edit: now it magically has 🤷‍♂️
Posted : 07/07/2022 5:37 pm
The pic is the right way up.
Posted : 07/07/2022 5:39 pm
The plastic wheels on my office chair broke off. Found some bearings same size and made em fit with selection of washers, a bolt and some tubing. Works perfectly
Posted : 07/07/2022 6:19 pm
See, now I'd want to do the other four to match.
Posted : 07/07/2022 8:09 pm
Hopefully this will see the holiday out. If not I'm sat on the grass
Posted : 08/07/2022 5:46 pm
Thats a quality bodge. but removing the flex of the frame might be all thats needed to complete the destruction of the material 😀
How much duct tape have you got? get it on before it rips!
Posted : 09/07/2022 12:05 am
Dropped my socket set & smashed the plastic insert.
ssss
Made a new one from foam floor mats & it's better than the original.
Posted : 09/07/2022 8:26 am
^ not a bodge, get it shifted
Posted : 09/07/2022 8:28 am
"Mended" a very very light and fragile steel road frame that had a 259 degree crack around the seat tube just above the bottle bosses by fitting a 400mm seat post the drilling through a bottle bolt hole and running a tap through. Nice m5 bolt and jobs a good 'un.
Currently looking out the window at the tandem I am convertig to a cargo bike. Bit of wood as a stokers top tube and no saddle currently.
Posted : 09/07/2022 8:35 am
Converted a Campag Record rear mech to a very long arm version with two alloy plates. In the days when MTBs were still U braked and Record was just old.
Posted : 09/07/2022 8:42 am
After 12 years of neglect, my favourite garden chair was showing signs that it would soon become firewood.
Bodged back into service using a bit of metal band and loads of screws…. Good for another decade I think!
Posted : 09/07/2022 2:27 pm
Isn't a badge that actually works reclassified as "suitable repair"?
Posted : 09/07/2022 7:21 pm
Fridge door hinge bush, the original is made of plastic & disintegrated. Now the door won’t shut properly & beer isn’t staying cold.
Bodge was a silicone sealant nozzle trimmed to fit the door socket.
Not a true bodge as I brought a couple of new bushes to replace it.
Posted : 09/07/2022 9:19 pm
This week my 20 year old track pump received some love. It was only cheap but has outlived several others and I'm kinda attached to it so didn't want to chuck it out.
First up, i always knew the gauge was way off. Turns out it's been out by 30psi! I tried taking the gauge apart to fix it but decided the best solution was to just to draw a new scale on a bit of card with felt tip pen, calibrated using the never-fail squeeze technique.
Also the original base got smashed during a fit of rage a while back, which made me sad looking at it, so I made a new one of of a lump of maple. Took a fair amount of hacking and drilling and I kinda like it, heavy and stable, though perhaps not a true bodge because I did put in some effort!
Other than that I gave the pump a good strip down and clean, ready for another 20 years of stickers.
Grrr stupid photos!
Posted : 09/07/2022 10:52 pm
This is really a clean and refresh of a previous bodge when we ran out of table space at a BBQ. Really useful for cutlery, condiments and napkins etc. so given the weather and time of year I thought I would share.
Build Guide
1) Find a plank
2) Drill a hole in each corner big enough for a bottle neck
3) Drink 4 bottles of wine
4) Rest the plank on the wine bottles
5) Sleep it off
Posted : 15/07/2022 2:04 pm
Surely nothing that involves drinking 4 bottles of wine can ever be classed as a bodge?
Posted : 15/07/2022 2:13 pm
Maple -- heavy and stable 🙂
Good repair sir
Posted : 15/07/2022 2:19 pm
[i]Surely nothing that involves drinking 4 bottles of wine can ever be classed as a bodge?[/i]
Look at the bottle on the top left of the table. It is a different vintage. That was the bodge, sorry, I should have been more specific
Posted : 15/07/2022 2:41 pm
Sewerage smell in the back garden traced to an old foul water drain cover without a double seal. Stretching an old inner tube in the frame channel has pretty much cured the issue. Low cost, low effort solution and now back to watching the ODI.
Posted : 17/07/2022 1:07 pm
Kitchen broom handle made of paper thin shiny metal was kinked by the kids a while back and it finally gave way the other day. I cut the ragged new ends off the two halves and found a plastic pipe which happened to be exactly the same size so wouldn't fit. Hacksaw blade to cut down the length of the pipe and a file run up and down within the cut was just enough to create a snug fit for the pipe within the broom handle to join the two halves. #timesarehard
Posted : 17/07/2022 10:57 pm
Just bought a Festool* 18v battery back from the dead by “jump starting “ it off another.
Connect up the + and - with a bit of old twin and earth stripped down to 2 separate wires.
Little spark from the + terminal and it’s ready to charge up.
Make sure it’s done in the open ….just in case
* other brands available
Posted : 24/07/2022 4:26 pm
The mini spray arm at the top of our dishwasher kept falling off. The ~10mm vertical tube it was attached to used to have a wee flange at the end which appears to have worn away over the last ten years, to the point the arm wouldn't stay on at all.
New part took all my google-fu to find and would be $110 posted...
Five minutes with my Leatherman and an old wire coathanger, and I present to you:
[url= https://i.postimg.cc/3xHjLq8R/IMG-20221016-164515.jp g" target="_blank">https://i.postimg.cc/3xHjLq8R/IMG-20221016-164515.jp g"/> [/img][/url]
Posted : 17/10/2022 8:17 am
^ well played.
Posted : 17/10/2022 8:51 am
Nice dishwasher bodge^^^
Very smart Jane pushchair given to one of the local Ukrainians. Great save for the bars that engage with the rear wheels for a parking brake were held on with thin plastic that had got old and broken. Fixed with scrap bits of aluminum, araldite and a roofing bolt*.
One side done 4 months ago and still working. Other side now fixed too.
[url= https://live.staticflickr.com/65535/52435657000_708d7175fb_k.jp g" target="_blank">https://live.staticflickr.com/65535/52435657000_708d7175fb_k.jp g"/> [/img][/url][url= https://flic.kr/p/2nTyrZJ ]IMG_20221017_194157033[/url]
*Roofing bolts also used to replace those missing from the cot donated for the same Ukrainian bairn.
Posted : 17/10/2022 9:26 pm
Dishwasher cutlery basket had developed a hole that meant cutlery would occasionally fall through and stop the rotor from spinning.
After a few minutes and several cable ties later…
Posted : 21/10/2022 7:06 pm
I had exactly the same problem but chose to use copper wire. It never crossed my mind to use zipties. So simple! 😊
Posted : 21/10/2022 9:54 pm
