What lube for a tig...
[Closed] What lube for a tight...
...fit 13 pin trailer socket on the car?
The new wagon has a rather snug fit electrics socket, and the bike rack plug is needing some lube. One of the new rotating 13pin things. Pins on plug are slightly corroded. It's taking huge effort to rotate it once engaged.
I don't want to either short out or insulate wrongly. I would rather not faff with rewiring unless I have too.
Posted : 02/04/2018 10:05 pm
I've got some of that stuff that I can't remember the name of. I think it came from RS?
Silicone Grease maybe?
Editย ย  https://uk.rs-online.com/web/p/greases/0494124/
Posted : 02/04/2018 10:16 pm
A bit of WD should help.
Posted : 02/04/2018 10:19 pm
If you can get some ..Ballistol Universal Oil in aerosol form ..
Posted : 02/04/2018 10:53 pm
Silicone spray.
Posted : 02/04/2018 10:54 pm
Vaseline has always worked fine for me on all my trailer connectors.
Posted : 02/04/2018 11:00 pm
Silicone spray +1
For plastics or rubber, it's a good idea to stick to silicon, as it's very unlikely to damage anything.
Posted : 02/04/2018 11:18 pm
That's good advice for life TBH.
Posted : 02/04/2018 11:46 pm
Vaseline works quite well for this
Posted : 03/04/2018 8:49 am
Another Vaseline user here on anything trailer/hitch related..
Posted : 03/04/2018 9:58 am
By the time Vaseline degrades the plastic in the connector your car will be obsolete.
Posted : 03/04/2018 10:10 pm
