What bearings for a...
[Closed] What bearings for a Cane Creek S8 headset?
as title!
Damn things have seized so need the model number.
Posted : 19/11/2009 2:06 pm
They were available off CRC under the model number IIRC? Bought a pair a couple of weeks back.
Posted : 19/11/2009 2:09 pm
I'll have a look ta! I can get them locally today if i know the model numbers.
Posted : 19/11/2009 2:15 pm
no model number and £30! 😯
Stuff that! Google isn't throwing up any numbers either
Posted : 19/11/2009 2:18 pm
just look on the bearing race and it should tell you the measurements. i did the same with my s8. the stock bearings are proper gash, its been a lot better since i bought some aftermarket ones.
Posted : 19/11/2009 2:19 pm
I had a knacked set of bearings in my Cane Creek S2 headset and Mike Cooksons in Whitefield sorted me out. I took the old ones out and took off the seals and then greased them up to use until I could be bothered swapping them, and they lasted another 12 months.....
..I know I should have swapped them when I was doing all that messing, but I'm tight..
Posted : 19/11/2009 2:27 pm
nothing on the remaining bearing i can see - nowt on the race or the rubber seal
Posted : 19/11/2009 2:29 pm
thats a bugger - have you tried the cane creek website? the tech section
Posted : 19/11/2009 2:30 pm
I suspect these will work just fine - [url= http://superstar.tibolts.co.uk/product_info.php?cPath=61&products_id=282 ]Superstar headset bearings[/url]
Posted : 19/11/2009 2:32 pm
