Welding info' ...
[Closed] Welding info' please
What king of gear do you need to weld steel or aluminium pipes together to make frames? I want to modify some frames to my spec' and wondered what kit I would need. I figured there will be some welders on here who will know.
Posted : 20/01/2014 7:22 pm
What you need there is a professional frame repairer/builder as the kit would cost more than a new frame and the jig to hold the frame in place to prevent it distorting is a very specialised piece of kit.
Posted : 20/01/2014 7:27 pm
Are you a welder stavromuller?
Posted : 20/01/2014 7:33 pm
You need an AC TIG welder - mine cost over £3,500 plus consumables. Then you need a frame jig - factor in £3k+ for one of them. Then you need all the metalworking kit - probably lathe, mill etc.
Then you need to be able to use all that stuff to a level that means you won't kill yourself or anyone else riding your bikes.
Apart from that, it's easy 😉
Posted : 20/01/2014 7:46 pm
dallas - would you know what to do with all of the kit?
serious question.. the fact you are asking the question hints to a response but...
Posted : 20/01/2014 7:48 pm
Interesting. £3500 is a non starter, I was thinking more 2nd hand mig off ebay. I only want to stick some tubes back together after I have cut them and re-shaped them. I'm not thinking of going into production. cheers anyway.
Posted : 20/01/2014 8:54 pm
might be best with pritt stick then, i hear its good.
Posted : 20/01/2014 9:07 pm
If you stick to steel you can get away with an oxy propane kit and brass braze. You will not be able to weld with this. You will still need a large amount of practice and undertake destructive tests of your joints. Not something to take a chance on.
You will not want on old set of hoses and regulators on a oxy propane kit so buy new.
Posted : 20/01/2014 9:09 pm
scotia - Member
It's not the best lip balm.....
Posted : 20/01/2014 9:10 pm
I'm a sheetmetal worker but I've welded enough aluminium frames to know that it's real tricky to get right and I think you can forget MIG for that but with any welding process, it's distortion that's the problem. Best advice is discuss with a frame builder what it is you want to achieve
Posted : 20/01/2014 9:18 pm
You can MIG thicker steel, but not aluminium - okay for thick 4130 maybe. Gas brazing steel would be cheaper, yes, but factor in the cylinder rental and gas costs.
Posted : 20/01/2014 9:37 pm
