VW T5 stereo replac...
[Closed] VW T5 stereo replacement........
Got a Kenwood dab stereo etc to replace the standard stereo but can't find the fascia/adaptor to turn the original double din into single din fitting and 'pocket' beneath. Found it for the post '09 T5, but not for my 07.
Need something like [url= http://www.ebay.co.uk/itm/VW-Transporter-T5-stereo-radio-Facia-Fascia-adapter-panel-trim-Double-CD-space-/181044316905?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2a27150ae9 ]this[/url]
Any help appreciated.
Posted : 17/09/2013 10:05 pm
Had a look at Skodas? The Octavia, like mine, has a regular DIN aperture, with a little recess underneath, which is where I stuff my iPod when it's plugged into my Kenwood DAB unit. Worth a look.
[edit] like this? http://www.caraudiodirect.co.uk/skoda-facia-adaptor-1.html
Posted : 17/09/2013 10:16 pm
Not directly helpful I know, but Halford's had nice JVC double-DIN CD players with the usual connectivity options and apparently compatible with OEM steering wheel/stalk controls for 99 quid. Might be an option if you can take yours back?
edit - or is this any use?? [url= http://www.mudstuff.co.uk/din-pocket.html ]DIN Pocket[/url]
Posted : 17/09/2013 10:21 pm
This has generally been covered to death on VWt4. If you ask on there I'm sure they'll point you to the right fascia for your head unit.
Posted : 17/09/2013 10:44 pm
I've fitted a double din dab unit from a polo went into my skoda ok do it should fit the t5.
Posted : 17/09/2013 11:09 pm
Reading the OP again, he has a double DIN space from the original stereo, which he's putting a single DIN unit into, and needs a pocket to fill the empty lower space, like my Octavia has, so tthew's DIN Pocket ought to do just fine, and only five squids, too. Do I pass GO, and collect my ten pounds? ๐Ÿ˜‰
Posted : 18/09/2013 12:55 am
Needs fascia, pocket, aerial and wiring adaptors - eventually found it as a kit.
Ta
Posted : 18/09/2013 6:56 am
