USB-C powered hub. ...
USB-C powered hub. Or injecting power?
I've got a 4 port USB-C Hub with 3 drives plugged in to it and 3 seems to be its limit. I plugged a 4th in and it doesn't mount the drive. If I plug it into a different USB-C socket it seems to work fine.
I guess that the hub can't cope with powering 4 things?
Is there a 4 Port powered hub I could use, I'm not having much luck searching for one?
Cheers 🙂
Posted : 29/09/2024 8:47 pm
Actually maybe I've found one? https://www.amazon.co.uk/Anker-Splitter-Connector-MacBook-Included-Gray/dp/B0CR6953Z2/ref=sr_1_28
Posted : 29/09/2024 8:53 pm
Yep that will do the job. Anker are a good brand so it has a much lower chance of catching fire than some no name eBay special.
Posted : 29/09/2024 9:05 pm
phil5556 and phil5556 reacted
Thanks.
I was going to order it but I’m sure it was £40 when I first looked then went up to £50?
Posted : 30/09/2024 1:31 pm
Currently showing as £29.99 on my amazon
Posted : 30/09/2024 6:07 pm
Cheers, same for me now & ordered.
Posted : 30/09/2024 6:15 pm
