TV Network at home
[Closed] TV Network at home
Second one from me today.
Can't find the thread (I think) I read last week where number and types of outlets were listed.
Got to redo the home network due to poor install workmanship and poor requirement choices.
I don't have Sky at the moment but I wouldn't like to exclude it later. I'm certainly not going to accept surface mount of cables if I do decide to get it. Access for cable runs and making chases is available.
Can someone confirm (or correct me) that I need the following -
At the 'main' TV point;
A quadplex.
A return aerial point (F-type).
A secondary phone socket.
Some data points - probably 4 as I'll just fit another twin back box.
At the 'secondary' TV points;
The above minus the return socket.
Or should I just make all the points the same as the 'Main'?
Posted : 05/04/2013 4:08 pm
At the TV Main point we have one similar to this:
[url= http://cdn.toolstation.com/images/130125-UK/images/library/stock/webbig/35074.jp g" target="_blank">http://cdn.toolstation.com/images/130125-UK/images/library/stock/webbig/35074.jp g"/> ?rand=348270224[/img][/url]
I don't see the point of adding returns to any other location. If you have a media server with TV tuners then add a return there.
We used CT100 cabling throughout, along with a StarBox splitter/booster, it's damn good! Also added Cat6 LAN cables and sockets. Two in each room and still a few things have to run off WiFi. ๐Ÿ˜ฏ Well worth doing.
Posted : 05/04/2013 4:55 pm
