TV Aerial but no si...
[Closed] TV Aerial but no signal!!
Any TV boffins about? Moved into a new house which has a 6 way aerial amplifier and an additional 2 room signal booster. Although the BT youview box works only when connected to the aerial socket, a conventional freeview TV says there is no signal. I've tried two different TVs in different rooms but again no signal from the various aerial sockets. Anyone know what I may be doing wrong? I've contacted the previous property owners, but all was working when they left. Any ideas? Thanks in advance.
Posted : 26/06/2014 9:21 pm
check the aeriel amplifier is switched on and plugged in.Usually in the attic or a utility room behind a flap or smmall access door.
Posted : 26/06/2014 9:33 pm
I've got good loft access and have checked the connections and even turned off and turned on both boxes again; still no signal. I've moved from Bucks to Wiltshire, numpty question, but will a modern TV automatically retune?
Posted : 26/06/2014 9:53 pm
 joat
You could try turning the TVs on and off with the remote or a long press of the standby switch. I thought our aerial had been damaged in the high winds as the telly said no signal, but a little angry technophobe prodding seemed to do the trick.
Posted : 26/06/2014 9:58 pm
Try doing a rescan with the tv plugged in.Look on MENU for rescan.
Posted : 26/06/2014 10:04 pm
 ton
daft question i know, but is there a aerial on the roof/in the loft?
Posted : 26/06/2014 10:07 pm
Yes, there's an aerial in the loft. I'll try the rescan and report back...
Posted : 26/06/2014 10:19 pm
Yes, both tv's needed a rescan; all up and running now!
Many thanks to your responses.
Posted : 26/06/2014 11:05 pm
