I have designed and built a web site for a client and I am wanting it to go live asap! Only once it was running on a test site has it has showed up a problem when viewing on IE 6&7 - bloomin typical. I have a drop down cascading navigation menu and on IE the options seem to stack and don't clear when rolling over to another option. Has anyone got a solution for this, is it something I need to add to my CSS or is it a bigger problem?! Thanks for any advice on this one I seem to have hit a brick wall on it!
probably to do with the box-model issue
try [url= http://css.maxdesign.com.au/listamatic/about-boxmodel.htm ]listamatic - IE box model[/url]
loads of other write-ups on it if you google
good luck
Use the correct doctype to force IE7 into "standards compliant mode" and it should behave properly.
Use conditional comments to include an additional stylesheet for IE6 that corrects all dimensions for the broken box model.
