These stove top fan...
[Closed] These stove top fan thingies...
... do they work?
Posted : 28/10/2014 8:18 pm
yes
Posted : 28/10/2014 8:19 pm
Bin dun lots in here.
Def yes
Posted : 28/10/2014 8:22 pm
Yup.
Unsettled the cats though.
Posted : 28/10/2014 8:32 pm
Over what sort of radius? There's one that shits in my garden.
Posted : 28/10/2014 8:33 pm
LOL - Limited I'm afraid; one cat refused to return to the sheepskin rug in front of the stove.
Posted : 28/10/2014 8:37 pm
I'm not convinced it makes a massive difference - but if you get the Stirling Engine one, it's a beautiful thing to watch swishing away by itself using science and stuff 🙂
Posted : 28/10/2014 8:42 pm
Got this cheap one thinking we could sell it if no good. Really happy and it makes a difference
[url= http://www.ebay.co.uk/itm/310637124702?_trksid=p2060778.m1438.l2649&var=610181838599&ssPageName=STRK%3AMEBIDX%3AIT ]http://www.ebay.co.uk/itm/310637124702?_trksid=p2060778.m1438.l2649&var=610181838599&ssPageName=STRK%3AMEBIDX%3AIT[/url]
Posted : 28/10/2014 8:45 pm
We were low in headroom, so bought this work of art for £185. Does make a difference to how fast the room heats up:
http://www.stovetopfan.co.uk/#/portfolio/copper-fan-ce/
Posted : 28/10/2014 8:51 pm
Really ? Well now we know they sold 1
Posted : 28/10/2014 8:58 pm
We have one, I forget which, about £45 if I remember correctly. I think it helps but not as much as some people say theirs does. We probably need to run our stove hotter to get more benefit from it.
Posted : 28/10/2014 9:26 pm
 Yak
Yes - makes a huge difference. But our stove is recessed into a deep-ish fireplace. The warm air movement due to the fan makes the whole room warm, not just the bit in front of the stove and the ceiling.
But when we had a free-standing stove in a previous house, that did a perfectly good job of heating the room without a fan.
Posted : 28/10/2014 9:46 pm
2; we were so impressed I ordered a second one.
Posted : 28/10/2014 9:47 pm
Just had our stove fitted today. 🙂
I'm intending on building one of those Zalman fans myself, looks pretty straightforward. Cost around £40-50 I reckon.
Posted : 28/10/2014 9:55 pm
No.
Posted : 28/10/2014 10:08 pm
maybe
Posted : 28/10/2014 10:26 pm
Maybe. (I like mine)
Posted : 28/10/2014 10:27 pm
Yes, and rest of house warms up too if leave the living room door open now.
Posted : 29/10/2014 7:49 am
Yes then very quickly for me no. It worked once then never again, the fan no longer turned. I believe it's because it got too hot! On investigation the instructions did say not to go above a certain temperature, so watch out for this.
Posted : 29/10/2014 7:55 am
Ta for the reminder one ordered.
An Ebay special.
Posted : 29/10/2014 7:57 am
 diz
Is there any to avoid or any that are recommended?
Posted : 29/10/2014 7:59 am
This is my one. It works excellently.
An eBay special, bought last December for £50 delivered.
http://www.ebay.co.uk/itm/Eco-Friendly-Heat-Powered-Stove-Fan-Warm-Air-Silent-Woodburning-NICKEL-BLACK-/350748358693?ssPageName=ADME:L:OC:GB:3160
Theyve dropped the price now to £45. Im just about to order a second one now I have a second stove fitted.
It says dont use over 345°C which is v v hot. I use a flue thermometer to make sure I burn between 200-250°C which is plenty ferociously hot enough. It would take some effort to get up to 345°C.
As you see, it comes with a [i]bona fide[/i] "Chinese Export" sticker for complete peace of mind 😉
[img] https://lh5.googleusercontent.com/-BrUVRa-u3iw/VFCg1DXorrI/AAAAAAAAK3c/4wF5zI6cAxk/s400/IMG_20141029_080638.jpg [/img][img] https://lh3.googleusercontent.com/-6UjSAv-QVzM/VFChCo3wYcI/AAAAAAAAK3k/Ia9X64EAiUM/s400/IMG_20141029_080647.jp g" target="_blank">https://lh5.googleusercontent.com/-BrUVRa-u3iw/VFCg1DXorrI/AAAAAAAAK3c/4wF5zI6cAxk/s400/IMG_20141029_080638.jpg [/img][img] https://lh3.googleusercontent.com/-6UjSAv-QVzM/VFChCo3wYcI/AAAAAAAAK3k/Ia9X64EAiUM/s400/IMG_20141029_080647.jp g"/> [/img]
Posted : 29/10/2014 8:12 am
Headfirst , you must have bought a gas one (designed for lower temps) or a duff one.
My genuine calframo ecofan which is now 3 years old sits on top of my 7.5kw alberg and
heats my whole house a peach.
When our eco fan was broke by a curious child dropping it we really missed it as the room , never mind the house took for ever to warm up.
Im tempted to try a valiant one as it looks just like my calframo and run them in tandem as the big stove gives out big heat.
Posted : 29/10/2014 8:14 am
As stoner poined out the degrees c of 345 thats 600 f and on the flue thermometor thats almost 3/4s of the way into tooo hot bracket . Stove will be on the verge of melting 😉
Posted : 29/10/2014 8:15 am
Think that's the one I've ordered Stoner. Worth a go as people claim they work on here everytime it's asked. I seem to get a lot of heat trapped inside the alcove so if it pushes some of that out then that'll be a bonus
Posted : 29/10/2014 8:50 am
Been tempted by one for a while. Only one spot on our stove gets hot enough (right hand side is about 90-120c, left hand side 120-180c) according to some fancy laser doodad. Glad they've come down from the £80 bracket when I was looking last year.
That's my Christmas pressie sorted.
EDIT: @ vorlich, the painting above your mantel is pants and sort your speaker cable out.
Posted : 29/10/2014 9:00 am
Drac - they work by initiating a more lateral circulation of air. Its not so much a "blower" as a mover. The graphic on the camaro (sp?) site is a good illustration.
You get a more even distribution of the heat. So rather than have a steep temp gradient across the room to the stove, say 17° rising to 23° at the stove you get a more dispersed 19-21° kind of gradient.
Posted : 29/10/2014 9:10 am
Are there any low profile ones? We don't have much of a gap between the top of the stove and the fireplace
Posted : 29/10/2014 9:13 am
james - see flaps post above ^
or that one below v 😉
Posted : 29/10/2014 9:14 am
The only one I found, I posted above (much to Trail Rat's shock). We have only 16cm headroom, so there wasn't much choice.
I have one that looks just like Stoners. It makes a worthwhile difference and if it broke I'd get another. It doesn't blow hot air at you, I barely realise it is working, but without it the room doesn't feel warm as quickly.
Posted : 29/10/2014 9:21 am
Thanks to my choice of a stove with a wood box underneath I also had this problem, not quite enough room. I used a sheet of metal to attach the fan to so it could overhang the stove by a couple of centimeters, enough that it stands in front of the chimney breast in my case. Footflaps fan looks nice but I am only poor 🙁
Posted : 29/10/2014 9:25 am
 Yak
I had a bit more room, but not enough for an ecofan style fan, so got a sirocco fan:
had to remove the metal carry loop to get a fit, but it works a treat.
Posted : 29/10/2014 9:40 am
the house I'm buying already has a stove installed, so I think one of those ebay jobs will be an essential house-warming present (see what i did there?)
Posted : 29/10/2014 10:09 am
Just ordered an ebay £45 job.
Posted : 29/10/2014 8:12 pm
Yup - that's a [i]fan[/i]tastic idea!
(See what [u]I[/u] did there?)
Posted : 29/10/2014 8:20 pm
Better? 🙂 cables will be done, I can't stand them messy...
Posted : 29/10/2014 8:52 pm
I find that hard to believe.... If your stoves only that your flue gas temp must be near freezing ( ok an exageration but stil)
How bigs the stove and how bigs the room
Posted : 29/10/2014 8:53 pm
Cheers Stoner kind of how I thought it would work.
Posted : 29/10/2014 9:50 pm
Bollocks!
The it's just a few mm to big for my stove the blades won't spin without heating the stone above the burner.
Posted : 01/11/2014 1:02 pm
Should have just bought on of these for less than £30...
http://www.cclonline.com/product/5552/CNPS9700-LED/CPU-Coolers/Zalman-CNPS9700-LED-Super-Aero-Flower-CPU-Cooler/CLR0232/?gclid=Cj0KEQjwidKiBRCevbT6yeqPrJQBEiQA1iM2WQ_qG5jgKN5Ho8xeH0OeYu5Mfrp3bhRRpRa0q7AvZb0aAhaI8P8HAQ
Posted : 01/11/2014 1:10 pm
Drac, pop the blade off and get busy with the bench grinder. Or I'll buy it off you for 40
Posted : 01/11/2014 1:22 pm
Alex, once you buy that you then need to buy the peltier device and a suitable base conductor. And then find out whether the fan is low voltage enough
Posted : 01/11/2014 1:23 pm
I'm considering getting the grinder on and cheers but I can return it for about £5
Posted : 01/11/2014 1:26 pm
Yeah fair enough, it wasn't really a serious remark, I just used to have one of those Zalman CPU fans (nice to look at but not great performance). Just seemed a bit pricey for some recycled computer parts and some not super expensive electronics.
Posted : 01/11/2014 2:24 pm
Yep!
Posted : 01/11/2014 3:27 pm
Weeeeeeeeee!
[URL= http://i.imgur.com/7AeSuhw.jp g" target="_blank">http://i.imgur.com/7AeSuhw.jp g"/> [/IMG][/URL]
Posted : 05/11/2014 1:04 pm
grindered?
Posted : 05/11/2014 1:05 pm
Fired ours up for the first time last night.
Not sure that it did much as there wasn't much of a draft, but it looks cool.
I was expecting it to be like being in an 80's Maxell audio cassette advert (one for you oldies 😉 )
Posted : 05/11/2014 1:17 pm
Yup small grinder and a file sorted it.
Posted : 05/11/2014 1:20 pm
top stuff.
Posted : 05/11/2014 1:21 pm
Seems to work pretty well, you can even feel when the air is cooling as it starts to push that out too. Takes very little for it to start spinning.
Posted : 05/11/2014 1:26 pm
