The process works b...
[Closed] The process works by infusing water with volts of electricity
this was in the newsletter from the sustainability team today. I've removed the link so it doesn't look like I'm spamming for some random company.
Cleaning Services are trialling a sustainable cleaning product which is made solely of water [website link available on request]. The process works by infusing water with volts of electricity, converting the oxygen in the water from O2 to O3 and thereby creating a highly effective cleaning solution. If the trial is successful, CLEANY MCCLEAN, Head of Cleaning Services has pledged to use the product at her own home. Watch this space.
Anyone heard of this??
Posted : 18/11/2019 4:32 pm
There's only one oxygen atom in water.
H2O.
Two hydrogen atoms.
Not sure what volts of electricity are sand how you infuse them. But I expect the process involves copious amounts of bull excrement.
Posted : 18/11/2019 4:35 pm
CLEANY MCCLEAN Head of Cleaning Services
chinny.
Posted : 18/11/2019 4:37 pm
chinny.
I believe the OP has redacted certain details
Posted : 18/11/2019 4:44 pm
ozone
Posted : 18/11/2019 4:45 pm
You can make hydrogen peroxide by electrolysing water (and dissolved oxygen from the air)
https://link.springer.com/article/10.1023/A:1017588221369
You can also create ozone (o3)
Either would be effective at disinfection, not sure they'd be much use for "cleaning" i.e. removing dirt/grease.
yeah for GDPR reasons I omitted her name. She's actually called Marigold Bogbrush
Posted : 18/11/2019 4:46 pm
I don't think they entirely understand the process but it's just ozone - O³ - from O². Not new. Iirc does show some promise in eliminating some bacteria etc.
Oxygen can clean things. It's how Vanish works - it's Sodium Perborate and it releases oxygen into the water. So it could be.
Posted : 18/11/2019 4:58 pm
You can make hydrogen peroxide by electrolysing water (and dissolved oxygen from the air)> https://link.springer.com/article/10.1023/A:1017588221369 < You can also create ozone (o3) Either would be effective at disinfection, not sure they’d be much use for “cleaning” i.e. removing dirt/grease.
This +1
Although I think there's a bit of information missing, it's supposed to be salt water?
It's used on a massive scale for things like the cooling water loops at power stations and refineries which tend to fill up with crustaceans if left to their own devices.
It's basically a very dilute bleach solution, but produced in-situ and turns back into salt water once it's finished.
Posted : 18/11/2019 5:21 pm
I believe Thames Water used an ozone plant to sterilise water.
Posted : 18/11/2019 5:24 pm
It's supposed to be pretty good at removing organic dirt, doesn't work so well on oil/grease. Although I think that's partly because the ozone is more stable in colder water, but colder water isn't somgood at removing oil and grease.
Posted : 18/11/2019 5:33 pm
Volts into water is electrolysis -> H and oxygen.
Putting something into highly arearated water is pretty much ultra sonic cleaning.
Creating ozone and holding it in solution within the water?
Posted : 18/11/2019 5:37 pm
Our cleaner (classic STW humblebrag) makes her own "green" cleaning solution with hydrogen peroxide.She was shocked when I explained to her that it can be used as a precursor in bomb making and that anyone buying large quantities is now probably being eavesdropped on by GCHQ.
https://cleaning.lovetoknow.com/Using_Hydrogen_Peroxide_for_Cleaning
Posted : 18/11/2019 5:43 pm
Yes, and free oxygen is a cleaning agent.
Posted : 18/11/2019 6:38 pm
 benv
Yes, seen this or something similar before that uses salt water. Used by FM companies in schools, hospitals, airports etc.
Posted : 18/11/2019 6:41 pm
Hot tubs have an ozonator (O3) in them for disinfection purposes.
Posted : 18/11/2019 7:09 pm
worst job I ever had.........
Posted : 18/11/2019 7:32 pm
I think the only process that really works by infusing water with volts of electricity, is accidental death in the bath
Posted : 18/11/2019 8:24 pm
Dammit. I infused water with currants instead of volts and made a fruity mess.
Posted : 18/11/2019 8:59 pm
Salt water make some more sense.
Posted : 18/11/2019 9:09 pm
Our cleaner (classic STW humblebrag) makes her own “green” cleaning solution with hydrogen peroxide.She was shocked when I explained to her that it can be used as a precursor in bomb making and that anyone buying large quantities is now probably being eavesdropped on by GCHQ
https://m.youtube.com/watch?v=Q2UTsthOfiE
Posted : 18/11/2019 9:11 pm
It's commonly used for small scale disinfection - e.g. spring water supplies. Easier and safer for Joe Public to look after than chlorine.
Posted : 18/11/2019 9:19 pm
They'll be putting dihydrogren monoxide in our drinks next.
Slippery slope.
Posted : 18/11/2019 9:25 pm
Lobsterisimus bumicisimus.
APF
Posted : 18/11/2019 10:30 pm
"Salt water make some more sense"
Well if you want to make, and then die from inhaling, Chlorine gas i'd agree.... 😉
Posted : 18/11/2019 10:36 pm
"“Salt water make some more sense” Well if you want to make, and then die from inhaling, Chlorine gas i’d agree"
My son (revising for chemistry GCSE) asked about this and it's not that simple. Electrolysis of relatively dilute NaCl solutions gives both Cl2 and O2 as they have similar reduction potentials. Concentrated solutions give more Cl2.
I had to look it up.
Posted : 19/11/2019 1:27 pm
It’s supposed to be pretty good at removing organic dirt, doesn’t work so well on oil/grease.
Every chemist's toes curl at this statement. Organic chemistry is the study of carbon compounds literally oil and grease are the foundation.
Posted : 19/11/2019 2:50 pm
worst job I ever had………
She had a huge bum...
Posted : 19/11/2019 2:51 pm
Every chemist’s toes curl at this statement. Organic chemistry is the study of carbon compounds literally oil and grease are the foundation.
Here we go again - but everything is a chemical.
I'd agree with you except a) a chemist said it and b) it is quite difficult to distinguish between oil and grease stains and the other types of organic soils, except I suppose you could say organic soils except for oil and grease based ones, which is more or less what he said. He never said oil and grease weren't organic, he just said it didn't work that well on them........
Posted : 19/11/2019 4:42 pm
TBF the hole thread makes my scalp itch.
Posted : 19/11/2019 9:15 pm
Well if you want to make, and then die from inhaling, Chlorine gas i’d agree….
Not quite. The chlorine created is immediate dissolved, creating NaClO - Sodium Hypochlorite - and H2. We use this exact process for killing bugs and shellfish in seawater systems offshore. If there's anything dangerous created in the process it's the hydrogen gas which we have to vent to safe spaces.
Posted : 19/11/2019 9:26 pm
