The Electric Car Th...
The Electric Car Thread
Yes, see my long rambling post from earlier. I'm with OVO and when I signed up to get a charger installed (back in November) the Ohme Home Pro was one of only two options, but a couple of weeks before the install (in May) I got a call to say that was no longer an option so went with an Indra instead.
I can understand them changing the recommended charger for new installs but it's a bit off if they stop supporting existing customers who installed the charger that they recommended only a few months ago.
Posted : 04/06/2025 1:03 pm
Looks like it's all driven by the need to distinguish where the power comes from, by the sound of it there's scenarios where a customer has solar and that energy goes in to the car but due to not knowing that, OVO give the customer a credit for the energy even though they never paid for it in the first place.
Appears that the chargers left on the approved list can provide that data and also explains why they now want the energy usage to come from the car rather than the now incompatible chargers.
Posted : 04/06/2025 1:18 pm
Did quite a positive post last year on our trip to France (440 miles each way) in an e+ Leaf. Repeated the trip this year and frankly, it was a bit of a pain in the arse. Plenty of planned stops that were easy last time involved a divert into the nearest town because we couldn't get on to a (usually sole) chademo charger and coming back on the last leg before the shuttle we had 4 attempts in a row where we couldn't get on a charger, ending up at the Coquelles Ionity on 2%. And despite cruising at 60mph the battery still got too hot and slowed charging right down. Electroverse card still worked everywhere and avoided any extra hassle.
CCS adaptor (now sub £600) would have avoided some aggro but the battery would have still overheated. They're a decent car for 300ish mile days but this is pushing it a bit too far. I think we'll be using the old petrol MPV instead and when the Leaf gets handed back soon we'll go for something smaller for an everyday runabout.
There's the same number of chargers at the aires we used as last year but way more French cars using them - some places could do with double or triple the number and still be busy. Lots of new Renault and Peugeot EVs, and I suspect it'll be a right pain in the proper holiday season. More off-motorway options now though, although since the chademo requirement has gone away many are 2-4 CCS and a 22kw AC.
Posted : 05/06/2025 11:20 am
Question- We have an EV, solar batteries and hot water, and need to charge/heat them all overnight to make the most of the cheap rate. I calculate 12kw max if they are all going at the same time, will we die? Now I know I can move things around time wise ( we have 6 hours, Octopus ), my big question is for the hot water, how long at 3kw will a 250ltr take? This is all worst case scenario as well ( winter ) and I know the three things are all separately fused and fed etc and the main fuse is 100a, but I just suddenly thought, wow, I could be drawing over 50amps at one go. Sorry, just the random worries of a novice.
Posted : 05/06/2025 11:31 am
Unless the entire tank is stone cold then you'd probably only need an hour or two with the immersion running. It won't heat the whole tank though unless you have a pump to stop it stratifying.
Fuse carrier might say 100A, fuse inside could be very different, so unless you've seen it, assume less. You can overload a 60A to 80A for an hour though, so I wouldn't be bothered anyway.
Overnight peak for my house is 85A at the moment.
Posted : 05/06/2025 12:07 pm
Posted by: andy8442
We regularly go over 50amp total, when I have the car charging, the oven (2 ovens actually) heating up, the hob on, kettle etc. The house is on a 100amp fuse
It always been fine, but the car charger is set to reduce its consumption if the total house load is over 80amps, I don't think we've ever got anywhere near 80amps.
Posted : 05/06/2025 12:34 pm
Let's do some science.  Specific heat of water is 4.2kJ per kg per degree C.  Assuming you want to heat 250l from stone cold (about 15C) to 50C (you don't need 250l of 65C water) that's about 10kWh, which would take 3h20 at 3kW.  Most immersion heaters are 7kW though no?
I think convection takes care of that? The immersion coil is at or near the bottom, so it would circulate?
Posted : 05/06/2025 12:56 pm
I'm seriously considering an ID.7 Tourer Pro S (nominally 422m range with a heatpump), now that would be totally sufficient for 90-95% of our driving but our annual summer holiday is Bristol > France loaded up with 3 bikes, enormous roof box etc. Anyone do similar journeys currently with roof boxes and bikes?? Does efficiency fall off a cliff?? I wouldn't want a 422 mile range to be say 50% worse.
ABRP reckons we could do Arras > Murol (this years destination) with 2 charging stops in 6h20m and arrive with 20% left, but that isn't accounting for the hit of 690L of roof box and the bikes.
Interestingly, standard google route planner puts the journey at 6h28m anyways. We'd usually stop once during the longer leg of these drives for food anyways (don't get me started on the lack of Gluten free food at French service stations though!) - the charging curve of the ID.7 means we could typically do 10-80% within the length of a usual stop, given we're shepherding two kids to toilets etc.)
Posted : 06/06/2025 10:44 am
Thanks @Molgrips. It's always good to see the numbers. I think am fixating on the 6 hrs low rate, and trying to squeeze everything in there, but in reality, with Octopus Intelligent Go, the car will charge out of those hours as well ( still at the low rate) so not as much pressure on those hours. I rest easy.....well, a bit easier.
Posted : 06/06/2025 10:50 am
Posted by: afrothunder88
I assume you'll be going in the hols? In which case factor in queues for the chargers, and yes the roof box, bikes etc will make quite the difference in range. We drove to the French Alps last year with friends, who decided to take their new Tesla. It was winter, with Skis and a roof box and four of them, needless to say the convoy stopped at Thurrock Services, and we met them at the Hotel in Calais, and then in Morzine the next day, 3 hrs later than us ( and I drive like Miss Daisy).
Sorry, but you'll just have to set yourself a more relaxed schedule, but hey , you're on you hols!
Posted : 06/06/2025 11:01 am
Roof boxes, 80mph driving and bikes on the back have a huge effect on any car, so yes.  Probably not 50% but a lot.  A trailer might be better.
But yes as above, you will need to have more stops.  It shouldn't really matter if an 8hr drive becomes a 9 hour drive, should it?  Is it worth paying six or eight times as much for your daily driving all year just to save two or three hours a year?
And it probably won't be two or three hours - you'd be surprised how long a toilet/coffee stop actually takes and how much charging can be done in that time. As I've said before, going to Scotland in my short range and very slow charging car we made 5 stops and only sat actually waiting for it for about half an hour. The rest of the time was spent buying or eating food, and weeing.
Posted : 06/06/2025 11:25 am
Even if it did fall dramatically that's still only a stop say every three hours, which you'd probably need to do anyway.
Posted : 06/06/2025 11:52 am
I am using Octopus Intelligent Go charging, and in the real world, the only time it doesn't make 100% by 6AM is if I get back from an occassional long trip and start at 20%. For day-to-day I don't usually need it at 100% so happy to charge over 2 night sessions.
If i need to leave with 100% i can boost outside low rate hours and charge at 27p/kW which is still pretty good value.
Posted : 06/06/2025 12:10 pm
Much as I would love a trailer we don’t have anywhere to store one short of paving over the front garden which would be a hard sell!
Yeah, I’m under no illusions how long the average stop takes, we were stuck in a McDonald's queue for 40 minutes when heading to Cornwall in the half term just gone. Can probably deal with 2 slightly longer stops, but yes, it is in the holidays, hadn’t factored in queuing for chargers really.
Possibly a moot point for this years trip anyway as a factory order likely wouldn’t arrive before it
Posted : 06/06/2025 12:20 pm
If you're going for an id7 then think about speccing it with the dynamic suspension option - apparently it makes a big difference to ride quality. Also note that some advertised features aren't supported in the UK - app controlled parking, walk up/walk away locking and the kick to open tailgate iirc
Posted : 06/06/2025 12:44 pm
Oh yeah, we’d be speccing the Interior and Exterior packs so it would be pretty loaded. Did not know about region locking of features though, that’s a bit annoying.
Posted : 06/06/2025 2:18 pm
I like that range of something like a Scenic (or Model Y) but not the size. So, now you've convinced me that built-in Google maps might not be as big an advantage as I thought, I've started looking for something smaller that still has a 350+ mile WLTP range. The obvious choices seem to be the EV3 or some variants of the ID3/Born. They all seem to have the heat pump as an optional extra though (and quite a rare option on the second hand models I'm looking at) which brings me back to the old question of whether a heat pump is important or not. For context I live in NE Scotland so it's a fair bit colder than it is down in Englandshire.
I know we've covered this already but it's hard to get any definitive numbers for the effect of a heat pump. Lots of opinions of course and people claiming the effect is significant, but very few numbers.
Best I've found so far is an estimate that a resistive heater uses on average 1.5kw to maintain the cabin at a comfortable temperature, while a heat pump would use around 0.7kw to do the same. So, on a long run, if you assume each leg is around 3 hours of driving (which is about right for me) the car without the heat pump would use around 3kwh more for each leg of the journey. Does that sound about right?
Posted : 08/06/2025 3:44 pm
@afrothunder88 my ID7 GTX tourer (car through work) arrives on Wednesday, I’ll let you know what I think. We have 5 and 9 year olds, I’ve been driving a loaner model Y and our trips have confirmed even with the low range etc we need to stop more for kids than we do for electric.
My behavioural/thinking change is that basically you just plug in when you stop. Never get too low never get too high. When we were going to NW Scotland, we actually had to rush to finish food because the car was full.
My impression of France last year albeit in our a6 diesel, was plenty of chargers at the service stations
Posted : 08/06/2025 3:49 pm
Posted by: susepic
?!? I realize that cars differ but at 95% charge or more I’ve found the regenerative braking on all our Teslas more or less absent. YMMV, I’d rather charge no higher than 90% and have full regen braking than get another 10-30 miles’ range.
Posted : 08/06/2025 5:16 pm
Posted by: roverpig
I think your arithmetic is fairly sound. I expect there are other effects to consider in cold weather but it’s about right to me. I suppose on that basis £1,000 or so for a heat pump (in those vehicles whose manufacturers don’t really want to sell EVs) that gives you ~15miles more range or saves you ~£0.30 on such a journey is maybe not so convincing?
Posted : 08/06/2025 5:21 pm
Our Buzz GTX has all of that working as standard, so it'd seem strange if it wasn't on the ID7.
(In response to the ID7 comment above)
Posted : 08/06/2025 5:49 pm
Posted by: monkeyp
Buzz gtx? Nice. Haven’t seen one on the roads yet
rhought they’d be super popular & everywhere
Posted : 08/06/2025 6:13 pm
I haven't seen any others either. Got ours a few weeks back. Long wheelbase, 6 seater. To be honest, the standard Buzz with a couple of options is the same price as the GTX which has everything as standard plus 4 wheel drive, larger battery, nicer interior and mahoosive wheels (which look awesome). Very happy with it so far.
Posted : 08/06/2025 7:03 pm
Posted by: monkeyp
I’ve got exactly the same as you .
I declined the wheel repair insurance from the dealer , then promptly kerbed it on the first day 😫 . Then did the passenger side front wheel a couple of days later in a tight drive thru 😤 .
£200 later , with them being repaired on my driveway ( who knew that service existed), I have been doubly careful since then. If I don’t scrape them again then I’ll be quids in 😎
Posted : 08/06/2025 8:06 pm
Yeah, in the Starbucks in Carlisle I had to get up and move the car because we hadn't finished eating.  Happy to say I saw a few other people doing the same - 8 rapid chargers and it was pretty busy.
Posted : 09/06/2025 9:34 am
Posted by: prettygreenparrot
Thanks. You are right that there might be other effects that I haven't considered. If we are just looking at cabin heating then it looks as though a car without a heat pump would use roughly an extra kwh for each hour of driving compared to the same car with a heat pump. That mattered when cars had ~20kwh batteries as you were losing ~5% of the battery every hour just to keep warm, but seems rather trivial when you have 60-70kwh to play with. Plus, of course, you are adding complexity to the system, which means higher repair bills and worse reliability in the long run too.
But, what if it isn't just about the energy used to heat the cabin and a heat pump provides other advantages I haven't considered? I think I'd still find it hard to buy a modern EV without a heat pump, just in case.
Getting reliable data on this is surprisingly difficult. There are various cars that have a heat pump as an option and loads of youtube channels from aspiring car reviewers all saying the same stuff. It's surprising that more haven't at least tried to test this.
There is lots of anecdotal evidence of course and the usual attempt to take one unreliable data point and extrapolate it to make some grand conclusion. But hardly anything you could really class as useful data.
The closest I've seen to a vaguely scientific approach was Jonathan Porterfield's video where he looked at data they had from over 40 cars, roughly half of which had a heat pump but were otherwise pretty similar (same make, model, weight, wheels, tyres etc). Unfortunately, while he showed the mean values for each month of the year he didn't give the standard deviation so it's hard to know how significant the results are or what the error might be. But taking the results at face value, for January, average consumption with a heat pump was 2.98 m/kwh  and without a heat pump this dropped to 2.66 m/kwh. So, if you were using, say, 50 kwh for a leg of a long journey then you'd travel 149 miles with the heat pump or 133 miles without it. Put another way, if you needed to travel 140 miles to get from one charge stop to the next that would cost you  47.0kwh with a heat pump or 52.6 kwh without one. So you'd need a slightly longer stop to recharge to the same point, but only a few minutes as you'd be at the part of the charging curve where charging was fastest.
That's the worst case scenario of course. By March that 140 mile journey costs 42.5 kwh with a heat pump vs 44.3 kwh without one and since Jonathan is based in Orkney his January figures are probably as bad as it gets in the UK. By the way, by July the cars without a heat pump actually gave a slightly higher average efficiency than those with one. But, as I say, he didn't give the variance so I expect this is just a random effect.
Posted : 09/06/2025 10:49 am
 mert
Do tesla still not have proper brake blending?
I just charge to 100% if i need it for the range and then let the car work out how much energy i can put into the battery on each brake application, whether it be through one pedal drive, or pressing the brake pedal. Then the "extra" is realised through friction brakes. Then i always get maximum range, and consistent behaviour.
It's surprising how little below 100% charge you need to be to get full regen.
Posted : 09/06/2025 11:19 am
Duplicate post...
Posted : 09/06/2025 1:11 pm
I picked up an ID7 ProS last week and haven't had chance to press all of the buttons yet, but will see if there is anything significant 'missing' once I've had a bit more time with it.  It's on standard suspension and smaller wheels, but I'd say the ride is pretty good - may be worth taking one for a spin before speccing the dynamic suspension.
It's a really nice car, really well built, quiet, and absolutely huge inside (parked next to a 5 series BMW this morning that looked smaller).  No complaints so far!
I'll be travelling around with a bike rack on the back a bit over the next few weeks, so will report back on range.
Posted : 09/06/2025 1:12 pm
Posted by: roverpig
Barely.  The heat pump is just the A/C run backwards. It has a few tweaks to allow it to work backwards but it's the same parts - compressor, condenser and evaporator.
Posted by: mert
On my Hyundai, the regen won't work for about the first 700m of driving, which in practice means the third or fourth gentle braking event.  On my Leaf, it wouldn't work at all until I got down to 95% and wouldn't work at full power until 90% I think.
Posted : 09/06/2025 2:22 pm
I see there is lots of man-math going on about heat pumps and range and cost. I've found in the real world on long trips, you just get on and drive and charge on a fast charger when the car tells you. I put it in eco mode and adaptive cruise to max the range, and then if i need to stop en-route for a charge I'll just find the best fast charger stop and have a wee and a coffee there. I might charge when i am at 50% (and need a wee)  and put enough in to get me to my destination rather than let it get low, and i can then top up on a slower charger when i am there.
Drove to Nottingham Uni oepn day, charged w 40% left on a fast Gridpoint on the M1 while haveing a wee to get me there, and then left it on a 7kw charger at the tram terminus while we visited. left to return with 100%, and stopped on the southern M1 to top up enough to get back to Sussex. Two wee stops as i suspect you would need in an ICE
Or I drove from Sussex to Brexity/Reform Norfolk coast last week. 190 miles. doable in one hit. Got there w 30% left, put it on a 150kw rapid charger when i got there, had a coffee and a bunfor 45 mins, went to my meeting with 97% charge, and then got back to Sussex w 30 miles (but that was into a head wind)
So you can do all the man math in the world, but it's actually very easy to live with in the real world. Appreciate if you are a road warrior who drives for a living that might change things a bit, but seems most of us on here are doing mostly majority local mileage.
Re driving to France, thinking of a Provence trip later int he year, so charging will be interesting. But i've found that in France in the summer it's crazy busy on the main routes anyway, so you're best getting off the autoroute for fuel rather than queue for pumps at services, or leave really early to miss the crowds. Suspect that will be the same thing for an EV (may eat my words on that mind)
Re the comment on 100% charge v regen braking - hadn't thought about that. I'll go to 100% for the range usually, but may adjust the target to 90-95% when i am just doing local trips.
Posted : 09/06/2025 3:04 pm
Posted by: susepic
My maths was strictly gender neutral I'll have you know 😀
It's a fair point though. One you have an EV the range is the range and you just get on with it. But when buying a car you want to make the "right" choice so knowing what effect a heat pump really has in practice is quite useful. Probably less than the effect of dropping your speed from 70mph to 65mph from what I've read, but still not sure I've understood it properly.
Posted by: molgrips
True, although there are some extra valves, sensors and pipework. Plus, I've never had a car where the AC didn't need fixing at some point. Usually just a re-gas but sooner or later they all spring a leak.
Posted by: molgrips
There is a lot of noise from the anti-EV brigade about how long it takes to charge an EV and what a pain that is. This leads to manufacturers pushing ever faster charging speeds. But once people realise that EV charging is something that happens while you are doing other things they might also realise that a car that charges too quickly can be as much of a pain in practice as one that charges too slowly. I guess the ideal is one that gets to 80% really quickly and then slows down to give you time to finish your lunch 😀
Posted : 09/06/2025 3:59 pm
Posted by: roverpig
I think some people don't like the idea that they may be forced to do "other things" while the car charges.
I've done my fair share of "long" trips over the last 45 years and in that time I can only remember stopping for food once and never "for a coffee" (they've always been drunk on the go).
The car may well charge while you're doing something else, but if you've not got something else to do - such as drink a crap cup of coffee or eat some unneeded food at a service station - then it may become an inconvenience.
Personally I can't think of anything I'd rather do less than to stop at a service station for 30 minutes or longer (presuming the charger works and there's no-one there already) and fill my time spending more money than I need to.
If the future electric car [which looks like an R5 atm] can't do what I need in one go then I'll take my ICE car that has a range in excess of 800 miles - so very likely there and back without any stops.
Posted : 09/06/2025 6:47 pm
I think that the “other thing” that you are, quite rightly, supposed to do is called “not driving “
It’s not really safe to drive long distances without taking the occasional break.
My EV conveniently provides a snooze button on the drivers seat which fully reclines the driver seat to allow for a swift kip if coffee / food /stretching your legs etc are “not your thing”
400 miles in one go isn’t safe for you or other road users, regardless of whether its in an EV or an ICE.
Posted : 09/06/2025 6:58 pm
400 miles for 1 driver is a lot but not so difficult for two.... I.e. me and Mrs SB.  2 minute swap.
Posted : 09/06/2025 7:08 pm
what’s the range like on the gtx ? And that pano roof 🙂
Posted : 09/06/2025 8:16 pm
The GTx doesn’t have a larger battery as far as I’m aware. Just larger wheels meaning marginally worse efficiency than the cheaper ones.
In terms of driving time and range, for a UK run where you tend to have relatively limited speed even on motorways they don’t seem to bad. But for a run down to the alps (about a quarter of our mileage) you’d be stopping for 20 minutes every hour and a bit (by the time you allow for charger spacing etc). The other issue is a couple hour trip to somewhere with no destination charger (llandegla, bpw, most sailing clubs and the like). That is a four hour trip that you would have to shoehorn a half hour charge into. Not an issue if you are time rich, but if you work and want to make the most of your weekends it’s a real drag.
Posted : 09/06/2025 8:46 pm
The LWB Buzz has a larger battery, so by default my GTX does. I am consistently getting 250 miles full range which is fine for me. The massive roof is very nice (although somewhat awkward to clean...).
Posted : 09/06/2025 8:56 pm
Posted : 09/06/2025 9:02 pm
thebunk reacted
Never mind battery capacity....As a male of a certain age, i workout journeys assessing time between bladder emptying. Sharkbait must have a much greater capacity than Minus....or am i overreading the situation?
Posted : 09/06/2025 10:24 pm
Sandwich and monkeyp reacted
Maybe it's time to adjust your attitude, for the sake of the environment?  I mean 100kg extra CO2 on a 500 mile journey just to save you 20 minutes doesn't seem right?  That said, I'm taking my diesel to Scotland at the end of the month, but I'll be feeling bad about it 🙂
Posted : 10/06/2025 8:55 am
You may want to get the confession to moving traffic offences removed.
Posted : 10/06/2025 10:43 am
 mert
Posted by: molgrips
But you get the full braking effect don't you? Even when regen isn't at full availability.
Posted : 10/06/2025 12:02 pm
Yes, IIRC there's no difference in the driving feel. However in the Leaf I seem to remember having to press the pedal a bit further if there's no regen available.
Posted : 10/06/2025 4:15 pm
I'm just about to decide on my new car. 90% sure I'm going for the Megane. My average work journey is about 125 miles, so I will cover 80% of my journeys on a single charge.
The luxury car tax limited my choices in the end.
Posted : 10/06/2025 5:05 pm
Page 197 / 235
