Cast fire bricks in my stove. Rear one is knackered. I ordered and have received the replacements. I cannot get the old ones out for love nor money! The only way I can see is two bolts that remove the back off the stove. Surely this isn't the solution?
Firewarm 4 stove is the make.
With my stove it's a case of removing the side bricks (and probably the riddle grate, and baffle brick too).. but my stove's not a Firewarm..
Took out the baffle. This sits into a ledge cast in the rear brick. I even unbolted the air wash system from the front yo hopefully swing the two side ones inwards but they're still behind the front lip. Bricks/plates are correct because they are genuine parts and the same shape/size! ๐ฟ
Tried looking for a pdf on the manufacturer's website? Youtube video?
No joy..
Last bump for the morning lot.
have you not given firewarm a call in Oirland?
Sent them an email. What's the call charges like from a mobile? Any ideas?
Less time on here, more time tackling the problem is my suggestion ๐
Come on twinwall you're a stove man, any ideas?
I've had a morning sorting things for work which has involved the need to check the Internet.
I'm putting off snagging the painters work ๐
My suggestion would be to put it on ebay and put the cash towards a Little Thurlow for M/F or Contura 51L, the best woodburner "in the world" {in a Jeremy Clarkson voice}.
Sorry never replaced the internals on a firewarm, but if you post some pics i may be able to point you in the right direction.
As for the Aldi question can't help, never been in a supermarket. ๐
