I need to work out a way of supporting an overhanging roof so that i can fit folding doors.
So my quandary is which should i use which deflects more for like for like steel gauge. I much prefer box section but i know fixing into it is going to be hard.
So answers would be appreciated and anyone who can give me an idea on price would be a bonus.
Size of box section approx 5x5 and similar i beam about 2.4m
Iain
wont your building regs guy want some structural calcs to go with that?
TBF I would probably wing it too, but if I wasnt sure enough to have a crack that I had to ask some stwers then Id probably choose to ask someone else with a degree or maybe a 10m Breaststroke certificate or something....
Sorry i should if explained that its a vertical support rather than a lintel.
The acrow prop that is there at the mo is doing a sterling effort but is not very aesthetically pleasing.Its not a full roof either its only about 2' pitched.
Cant help - Im a luddite and I would use an oak pillar anyway ๐
You need to explain a bit more, it's not possible to picture the situation
I'd try to cantilever it so didn't see a support?
PFC
As above.
Why is it being supported in such a temporary way?
Some pics may help ๐ก My son may be able to suggest a solution being into structural engineering stuff ๐ก
Vertical supports are normally box section (from what I've seen).
You've not seen many proper ones then ๐
As a rule most vertical supports will be in the classic rsj format (or I beam/hbeam etc) or as pfc.
Pfc being basically a squared off u shape.
Using a PFC on current extension. Used small UB on a previous one
Theres nothing in a house that can't be supported off a good old 152uc. But if you are a stwer then I recon you might want something niche, how about an asb? Bit of structural engineer humour for you. In seriousness though, unless its barely holding anything up of anything significant I wouldn't start guessing at it if I were you. If not, then I say 152uc.
are you building a centre for global trade in say, new york?
best make it conspiracy proof!
For a vertical support a box section would be a better choice as its properties will be symetrical in both directions. An I beam (UB) is designed to be stronger in one plane than another. A column section (UC) would be more suited as a vertical support, but for looks, a box section looks better/less industrial and if an acrow prop is supporting at the minute, then a box section/UB/UC are all likely to be stronger. However as above, I doubt there would be anything in your house that a 152x152 UC wouldn't support!
