Sourdough starter?
[Closed] Sourdough starter?
have my 3rd attempt at a sourdough loaf fermenting on the fridge overnight....ready for baking tomorrow... I have cut down a great deal with the water to the reciepe, I now have a firmer more workable dough this time.... will get some pics posted up of the baked article whence it's goose has been cooked....:-)
Posted : 24/04/2020 9:12 pm
Looking pretty good if a bit squiff. The starter was fed with semolina last night which it seems to be more than happy with.
null
Posted : 24/04/2020 9:49 pm
The bake with Jack beginner sourdough (on his page, not the video) has a step by step run through, have a look. I’m planning on using this method until I get a fair grasp on what works best for me, then I’m for branching out a bit and trying other methods.
yep, seen it thanks, i think its pretty much the same as the video, so will use that to make my next loaf.
I’m not sure but I normally take mine out of the fridge and feed mine up at 10pm with 100g wholemeal or rye flour and 100g cold tap water and put it on the kitchen counter – when I wake up its bubbly and risen so it’s good to go.
thatll do for me, thats me sorted then, ill feed it the evening before mixing and then get to work on it the next day.
thanks
Posted : 24/04/2020 11:55 pm
sadexpunk... sorry I didn't have time yesterday to follow the link and find out what the bake with jack method was.
To summarise my usual procedure...
Day 1 pm - take starter out fridge, warm up, feed
Day 2 am - build levain (take some of the starter and add flour and water - feed it, essentially - to make the bit that will go into the loaf)
Day 2 pm - make dough, fold and stretch, start bulk fermentation
Day 3 am - divide, shape and start prove
Baking might happen day 3 pm or day 4 am if it's proving in the fridge
All the details and pictures are in my post on the previous where I embedded some Facebook posts (I can see them but did that work for everyone else?).
I think I mentioned it before, but timing is really key with your starter (and levain), but it's really dependent on temperatures and your flour so you need to experiment and get a feel for it.
The best way to do that (I reckon) is to find a time when you're at home (and awake) for a good while (ideally all day) and feed your starter then come back to it every so often and see how it changes (and mark the level on the jar or whatever if you want). It'll expand (while the sugar in the flour is consumed) and reach a peak where it's most active, then (when the sugar is all used up) start to fall back. That peak is where you want get some off it and use it to make a levain. Then the cycle starts again and you want to get the peak of that when it goes in the rest of your dough.
The only way to get a feel for how long it takes to reach the peak is to let it go too far, but you learn. Temperature has a big impact. If I want change my timimgs to fit around something else I'm doing, I'll speed it up by adding warm water for the feed and/or putting it in a warm place, or slow it by using cold water and/or putting it in a cooler place. I can probably vary it between 4 and 12+ hours depending on the flour. Flour is the other variable. Rye and wholemeal seem to work a bit quicker, while white is slower, but it'll depend on your particular flour.
HTH
Posted : 25/04/2020 12:08 pm
getting there.... more practice needed..
bread
Posted : 25/04/2020 12:12 pm
Looking good davy-g! And looks like you've got supplies to keep you going too.
Took some more pretentious photos of my pretentious bread...
Writing this while enjoying a few slices of the tin loaf grilled with some blue cheese. Actually baked these on Thursday, but we were finishing the previous loaf. I gave the boule to some friends who are on 12-week isolation. Even giving a loaf away every time I bake, there's still too much. I'm going to make pizzas with the dough that's proving now so we can catch up.
Posted : 25/04/2020 4:50 pm
Some nice looking bread up there!
Posted : 26/04/2020 8:13 am
ive done 3 days, last fed yesterday lunchtime, got up this morning and it looks a lot more like a starter should be, bit bubbly and increased in volume. it was just a thick shaggy mess when i left it.
im a little surprised at how it looks this morning as thats maybe 18hrs after feeding it, id have thought even if it was spot on then itd be at its best mebbes 6 hrs after feeding and have died down by now….
well, ive just tried this method and unfortunately a disappointing result now ive just got up.
as previously mentioned, building the starter id been feeding 25g/25g rye/water over 3 days. feed at lunch, leave on windowsill, same again 24hrs later. 3rd day it had bubbled up (18hrs later which surprised me) so thats when i asked about timings so that i could look after it ready for baking a few days later.
so as the above method ^^^, in the fridge it went, took out yesterday evening to warm up, then fed it at around 10pm.
got up this morning hoping for a bubbly concoction and it bahhhh, it doesnt look much different :-/
im thinking back and trying to work out whether its bubbled up and died, or not bubbled up yet. its history suggests it hasnt risen yet, as when i fed it at lunchtime and was then surprised at its bubbles, that was the next day, at room temp. so could it be that my starter is at maximum life close to 18 hrs later? that sounds daft!
i was expecting to get up to a load of bubbles and seize the day and start mixing early-doors. ill give it a few more hours and see if it shows any more life.
To summarise my usual procedure…
thanks northwind, bit more complicated than what im trying but ill keep that in my back pocket in case i need to try something different.....
EDIT: although reading back, the timings seem to be similar to my method anyway, feed at night, ready in the morning, if i understand correctly tho, you then refeed that in am then mix in the pm.
ill leave mine for now, see if i can get a feel for when it rises.
thanks
Posted : 26/04/2020 8:44 am
Looks superb Davyg!
Posted : 26/04/2020 9:16 am
tasted good...chewy but tasty.. I may be able to add a tad more water to the mix next time.. as this one was kinda dryish and that made for a tighter crumb...makes for lovely toast and marmalade though..LOL
Posted : 26/04/2020 9:45 am
Sort of... feed starter at night, ready in the morning, when I take some of that and put it into a levain, and the starter goes back in the fridge. Making a levain is basically feeding the starter again, yes, but it's different in that the starter is kept for the next time, whereas the levain (all of it) ends up in the loaf - though it's just semantics really.
Good crumb davy-g. I too kind of crave that really open airy crumb you see from the true experts, but in all honesty, something like our loaves (my best loaves look similar to yours) is much more practical for actual eating, which is the point!
Posted : 26/04/2020 11:40 am
nope, 6 hrs or so later and no sign of much life, certainly not enough for me to think its become lively enough to bake with, so just fed another 25g/25g rye/water and will monitor this over the next 10 hrs or so......
Posted : 26/04/2020 2:05 pm
well, i believe the official term is..... its dead as a dodo :-/
bubbled up on feed 3 (75g), refridgerated ready for feed 4 but then never rose again.
feed 4 (to a total of 100g) was before bed then still flat in the morning, i did the extra feed yesterday (125g) at around lunchtime, kept an eye on it and it never rose past my elastic band marker. neither before bed (10 hrs later), nor this morning.
dont know where to go now..... looks like ill probably have to start discarding and feeding til it shows signs of life again.
Posted : 27/04/2020 8:45 am
took my starter about 10 days to become fully active and ready for baking with, at no time did I place the starter in the fridge during that period, I only done that once I had used the first batch and used the cold of the fridge to slow things down until the next time It was needed for baking with...
Posted : 27/04/2020 9:29 am
ok, so how much starter did your 10 days worth of feeding give you, and how much do you use/discard each loaf?
thanks
Posted : 27/04/2020 9:52 am
I started of with 100g of both flour and water, the next day I kept 70g of the mixture and added 100g each of water/flour to this, same for the next day and the next day, kept 70g and kept adding 100g each, until the starter became active and useful for baking (I performed the float test with the starter).
I use 100g of starter for my bread, and then place the remainder in the fridge to slow things down, I get the starter back out of the fridge when I am going to be baking more bread, I leave it to sit on the kitchen worktop for a few hours to acclimatize and then add 100g water/flour and leave to ferment....once it has doubled in size then it is ready for use....take what I need and then return remainder to fridge... I usually have about 270g of active starter for my use...
Posted : 27/04/2020 10:08 am
If it's not reacting at all to feeding, that suggests there's no live yeast cultures in it, or very few. Usually there's enough in the air or on the flour to get a high enough concentration, but you could try adding something that's more likely to have some on: apple skin, grape skin (preferably organic - the yeast is less likely to have been killed by pesticide). Even better flour if you can get hold of it (difficult at the moment I know) - stoneground (the heat from steel milling kills the yeast) and organic (same reason as before) will have more yeast on it.
Posted : 27/04/2020 10:25 am
forgot to mention that I used strong white bread flour....
Posted : 27/04/2020 10:40 am
I used SWBF for the first 3 days, then got some rye flour, was like adding Nitro!
Posted : 27/04/2020 10:43 am
hmmm..... mines fully rye, so i expected great things.
thanks for the info, ill persevere......
Posted : 27/04/2020 5:06 pm
Another batch started today, 2/3 SWBF, 1/3 SWholemealBF, be baking tomorrow morning, as my Bannetons arrived from scotland the bread this morning, thanks @Albanach
Posted : 27/04/2020 5:08 pm
Excellent. What’s SWBF?
Posted : 27/04/2020 10:02 pm
Sorry, strong white bread flour!
Posted : 27/04/2020 10:12 pm
fed last night, still nowt this morning so id like to ask a question please.....
say i keep trying to build this starter for another few days, and remove say 50g each evening and refeed. i know some people use the discarded stuff for pancakes etc, but i dont really want pancakes. but i dont want to just chuck it away either, its a waste.
im thinking i could save each 50g in another pot, keep it all in a pot and then make pizzas one night with it instead. so in effect im 'stockpiling' the flour and water ready for a recipe?
so, say ive got 200g starter squirrelled away in the fridge, and a pizza recipe calls for 300g flour/200g water, ive now started that off with 100g of each and just need less to make the dough yep?
and......if thats right, would you then put yeast in too, as this is basically just flour/water from a dead starter?
tbh ive never really understood why yeast is an ingredient in pizza recipes, as youre not really looking for a rise as such, and can make pizzas soon after mixing if you so wished. whats your thoughts on these questions please?
thanks
Posted : 28/04/2020 9:20 am
I always put yeast in my pizza as I prefer a softer risen crust like a Neapolitan type. Normally use about 60-65% hydration and 0.2% yeast.
I’ve not tried dourdough pizza yet but Here is a video of Patrick Ryan making one and he does add a wee bit of yeast as well as the starter.
Posted : 28/04/2020 10:06 am
I made it without yeast, was grand. I like to make mine with just sugo til it's half done, then pop the mozz on. Like it crispy.
I also freeze a few.
Posted : 28/04/2020 11:16 am
Sadexpunk, there's a vid on bake with Jack about dead starters, suggests too much of it? Worth a watch.
Anyway, 2nd effort. 2/3 white, 1/3 wholemeal.
<img src="[img] [/img]
[url= https://www.flickr.com/photos/nobeerinthefridge/49829283232/ ]20200428_095843[/url] by [url= https://www.flickr.com/photos/59995395@N03/ ][/url] - [url= https://play.google.com/store/apps/details?id=com.dariogf.flickr2BBcode_lite ]Flickr2BBcode LITE[/url]
" alt="" />
Posted : 28/04/2020 11:19 am
👆 great looking loaf. Crumb pic?
Posted : 28/04/2020 11:24 am
Sadexpunk, there’s a vid on bake with Jack about dead starters, suggests too much of it? Worth a watch.
thanks, hadnt seen that, just had a look. he recommends binning most of it and starting again with 25g or so, so thats what ill get cracking with tonight. ill put most of it in a separate jar ready for some pizza.
cheers
Posted : 28/04/2020 1:05 pm
A bit of a sandwich crumb, due to the 1/3 wholemeal, possibly a tad more versatile than pure white airy sourdough.
[url= https://www.flickr.com/photos/nobeerinthefridge/49829411291/ ]20200428_130548[/url] by [url= https://www.flickr.com/photos/59995395@N03/ ][/url] - [url= https://play.google.com/store/apps/details?id=com.dariogf.flickr2BBcode_lite ]Flickr2BBcode LITE[/url]
" alt="" />
Posted : 28/04/2020 2:12 pm
Today's effort. Wife's kneeding, my shaping. Think this one has some spelt in it.
Posted : 28/04/2020 2:23 pm
There are some good looking loaves on this thread.
Posted : 28/04/2020 2:26 pm
I have had a first go at sourdough today. I used the BBC food starter and it seemed to go from the off, it looked and smelt right, and it seems to have worked okay today, the breadsticks anyway are really good, I think the loaf may be a little dense and will need more proving next time.
Posted : 28/04/2020 2:30 pm
First ever attempt at sourdough - I’ve been making soda bread most days since lockdown started, so decided it was time to step it up a bit. It was made with a ‘no knead’ recipe, and I’ve another due in the oven in 3hrs which I made following Patrick Ryan’s basic sourdough process. Will remember to brush excess flour of the next one!
Loaf
Posted : 28/04/2020 2:56 pm
Superb, all looking good!
Tried a different pattern on loaf #2 (agree with bake with Jack, your as well doubling up and making 2 loaves, while you're at it)
[url= https://www.flickr.com/photos/nobeerinthefridge/49829560226/ ]20200428_104827[/url] by [url= https://www.flickr.com/photos/59995395@N03/ ][/url] - [url= https://play.google.com/store/apps/details?id=com.dariogf.flickr2BBcode_lite ]Flickr2BBcode LITE[/url]
" alt="" />
Posted : 28/04/2020 3:03 pm
We have a freezer shelf full from doubling up 😀. Now using the second half as pizza dough 👍.
Posted : 28/04/2020 3:09 pm
Second effort, using Patrick Ryan’s kneaded recipe - much less faffing about, and a much better looking result. I’m really quite chuffed with that, given today’s my first foray into sourdough baking.
Sourdough
Posted : 28/04/2020 6:32 pm
Superb dj!
Posted : 28/04/2020 9:11 pm
Some early morning sourdough baking done. Followed @sourdough_tim recipe so a couple of 24% wholegrain 78% hydration loaves
Posted : 30/04/2020 11:48 am
4th attempt today.... started a full white loaf (no wholemeal added at all) today... it's in the fridge doing a long ferment..... see what happens in the morning when it's baked... added a tad more fluid to this mix... but not to much to make it sloppy....
must admit that the starter went mental within an hour of feeding it.....LOL
Posted : 01/05/2020 7:16 pm
Not sourdough but, for those asking about out of date yeast, today I made this using dried yeast that was over two years old.
It weighs the same as the sun and is only good for breaking up a patio.
Posted : 01/05/2020 7:24 pm
must admit that the starter went mental within an hour of feeding it…..
i dream of days like that 😀
Posted : 01/05/2020 7:26 pm
Double feed of mine today for a first try at this easy, no kneed, fairly quick recipe tomorrow...
https://bakerbettie.com/no-knead-sourdough/
Posted : 01/05/2020 7:42 pm
My first attempt at a loaf today using a homegrown sourdough starter.
Tasted great although a bit heavy. I think I was a bit heavy handed during the folding stages and knocked too much air out of the dough.
Posted : 01/05/2020 8:09 pm
My starter’s been ticking over on the dregs of a bag of flour for the past week. Managed to get 3kg today from a local deli so have a loaf waiting for its overnight prove.
I made some crumpets with the discard this morning when feeding. Milk and self raising added by eye with a pinch of salt and sugar. Bit of an experiment as I’ve never tried making them properly before. I didn’t get the temperature right until the last one, low and slow!
Posted : 01/05/2020 9:43 pm
Page 5 / 8
