Singletrack Dr’s he...
[Closed] Singletrack Dr’s help please - leaking elbow
I had my booster on Tuesday night. Today my elbow (same arm) is leaking / feels wet. Wife has confirmed it feels wet and clammy so can’t be my imagination. Any ideas ? Don’t want to bother NHS if it is a common side effect as I understand they have there hands full atm
Thanks
Posted : 16/12/2021 7:34 pm
i guess its serious if no one can bring themselves to break the bad news to me
Posted : 16/12/2021 10:16 pm
Ianad but is the injection wound weeping and fluid going with gravity to the elbow?
Posted : 16/12/2021 10:23 pm
Can't you phone NHS 101 or whatever its called?
Posted : 16/12/2021 10:24 pm
Can’t you phone NHS 101 or whatever its called?
Not sure they have qualified Audi driving IT middle managers?
Posted : 16/12/2021 10:32 pm
Well I suppose blaming your booster jab is one way of explaining carpet burns to your significant other.
Posted : 16/12/2021 10:52 pm
 DrP
Is the elbow just wet, or is it actually leaking from, like, a hole??
Is there a 'gaelic shrug' emoji I can use?
DrP
Posted : 17/12/2021 10:24 am
At least yours is leaking out before it does that.
Posted : 17/12/2021 10:39 am
Is there a ‘gaelic shrug’ emoji I can use?
I read that as Garlic shrug and was very confused.....
Posted : 17/12/2021 10:42 am
Do you have a cat or know someone who has one?
Fashion some shoes for it (the cat, not your arm, that would be silly).
That should take your mind of your moist appendage.
You are welcome
Posted : 17/12/2021 10:49 am
Sounds fatal to me, can I have your bikes?
Posted : 17/12/2021 10:51 am
Either post pictures, or go ahead and start a 'What tyres for a leaking elbow...' thread.
Posted : 17/12/2021 12:32 pm
Are you entirely sure that's your elbow?
Tell us, does it usually live in your sleeve, or your trouser?
Posted : 17/12/2021 1:02 pm
Sounds like something that might happen elsewhere on the body. Can you tell your elbow from your arsehole?
Posted : 17/12/2021 1:19 pm
Try a wrap of ptfe tape.
Posted : 17/12/2021 1:21 pm
Lick it and tell us what it tastes like
Posted : 17/12/2021 1:23 pm
Have you taken a knock to the elbow?
5 years ago I slipped going down some stone steps and clocked my elbow hard. It swelled up and started leaking fluid from a small hole. The lump lasted for some months and could produce fluid whenever squeezed. Mates were highly impressed by this and nicknamed it the Swellbow.
It eventually sorted it's self out and is now a thing of legend.
Posted : 17/12/2021 1:27 pm
My fellow training team at work now think I'm an idiot (fair probably) as, not for the first time reading STW, I have deposited my coffee on my laptop!
Posted : 17/12/2021 1:44 pm
Irish?
I'm wondering if they invented it and the French took it over to make the Gallic Shrug.
Posted : 17/12/2021 1:48 pm
 DrP
meh..spellin innit
DrP
Posted : 17/12/2021 1:54 pm
It's Cat Aids and the bad type. You'll not see another Christmas (thanks to my departed FiL for that one). What bikes are we going to squabble over?
Posted : 17/12/2021 2:25 pm
Thanks for your responses sorry I haven’t commented yet As I have actually been out riding my bike.
My elbow is wet / clammy there is no sign of any leakage from the injection area.
I guess it is a very serious issue if the Singletrack minds are baffled.
Not sure my bikes are viable proposition once all the repairs needed have been carried out
Posted : 17/12/2021 5:26 pm
Has anyone told you that "you don't know your arse from you elbow"? Is it actually a different sort of leakage you're asking about?
Posted : 17/12/2021 5:35 pm
meh..spellin innit
DrP
I thought it was handwriting you were supposed to be bad at.
Posted : 17/12/2021 5:39 pm
Your mates were impressed when you ejaculated liquid from a tumescent body part?
Posted : 17/12/2021 5:44 pm
Just pray it's not Bursitis (infection of the protective fluid sack on the elbow), I had that once, I could have cried it was so painful. Also, then going, getting anti-biotics, forgetting to tell the doctor about my mild allergic reaction to pencillin (causes throughfall), THEN walking the national 3 peaks later that week was not my best week. The portaloo at the bottom of Scafell was bad when I arrived, but SO much worse when I left it, I'm sorry to anyone else who ever had to use that portaloo, no amount of high pressure cleaning could have restored it.
Posted : 17/12/2021 6:01 pm
The leak could be anywhere, it is just coming out at the elbow. Take it apart and re-tape it, it'll be fine.
Posted : 17/12/2021 6:09 pm
This could end up like molgrips Mercedes thread!
I’m going with perspiration…
I’ve seen all sorts, nothing would surprise me
Posted : 17/12/2021 6:16 pm
Do you need ridiculously expensive bleed kits for this leak? You must have a SRAM elbow yes??
Posted : 17/12/2021 6:20 pm
Subscribed
Posted : 17/12/2021 6:35 pm
Did you put SLIME in it ? or STANS ?
Posted : 17/12/2021 7:00 pm
Have you placed your elbow in a puddle without realising?
Posted : 17/12/2021 7:06 pm
Have you tapped it?
Posted : 17/12/2021 7:11 pm
I've a bearing press to hand, if that might help.
Posted : 17/12/2021 7:44 pm
have you checked for corresponding overly-dry patch somewhere else?
Posted : 17/12/2021 7:54 pm
Put your other hand on your hip and put the the leaky arm out to one side with the palm facing down and a slight bend in the offending elbow.
Then slowly tip over in the direction of the leaky arm and you should feel the liquid pouring out.
Posted : 17/12/2021 8:17 pm
You probably need to re-tape it in order to prevent fluid leakage past the holes. (or nipples, oh err doctor)
Posted : 17/12/2021 8:56 pm
Has this been going on all week or has it just been one day like this? Don't get it on the carpet, could be grounds for divorce
Posted : 17/12/2021 9:18 pm
We need an update - did it explode?
Posted : 19/12/2021 11:56 am
It's classic symptom of the new olecranon variant - we'll all have it by new year
Posted : 19/12/2021 12:08 pm
I think the OP has leaked away. Just an empty bag of flesh somewhere with a slightly damp elbow the only evidence of their existence
Posted : 19/12/2021 12:10 pm
