Single(CupTeaStrain...
[Closed] Single(CupTeaStrainer)TrackWorld
I usually use loose tea for a cuppa these days. Got one of those one-cup things like this:
It works OK, but I get bits in my tea, particularly with very fine tea like rooibos. Anything better out there? (And no, don't suggest teabags).
Posted : 27/01/2020 10:57 am
I wonder if there's a market for sonething very much like a pot for brewing tea in... :p
Posted : 27/01/2020 11:00 am
If you're suggesting a tea pot, yes I have one of them 🙂
Want something that I can just use to make a single cup, then dump the leaves and rinse under the tap for the next one, rather than a pot full of leaves that needs cleaning out (and pre-heating so you don't end up with lukewarm tea).
Posted : 27/01/2020 11:05 am
I use one of these Finum brewing baskets. It is a pretty fine mesh, seems to keep all of the tea leaves in. Also works nicely for coffee.
https://www.amazon.co.uk/Finum-Brewing-Basket-Permanent-Filter/dp/B000I68NCS
Posted : 27/01/2020 12:33 pm
 WBC
+1 for the above
Posted : 27/01/2020 12:43 pm
Looks good, cheers
Posted : 27/01/2020 1:51 pm
Same company, different product.
https://www.amazon.co.uk/finum-Litre-Control-Steel-Coaster/dp/B003VQRGX4
I have a one-cup and a two-cup version, they're great. Unlike a regular teapot you can 'switch off' the brewing so that you don't end up with a stewed brew. You can dump the leaves out of the basket and rinse, and it's pretty thin so doesn't leach all the heat away like a conventional teapot.
TBH though, half the time I'll just dump loose leaves directly into the mug. That's how my grandparents made tea, it was years before I discovered it wasn't the norm everywhere.
Posted : 27/01/2020 2:37 pm
 Pyro
My missus just bought one of these:
https://www.t2tea.com/en/uk/teawares/brew-set-on-the-go-grey-H999BU147.html
I think she's trying to find a tea-making counter to either the Airopress or my Minipresso...
Posted : 27/01/2020 4:34 pm
Unlike a regular teapot you can ‘switch off’ the brewing so that you don’t end up with a stewed brew.
Without wishing to appear ungrateful for the advice, the one CraigW and WBC recommended has that function: you take it out of the cup.
Also (and admittedly this wan't part of my original spec) it needs to be cheap enough that I can buy a 2 or 3 for making different types of tea at the same time, which the brewing basket is.
Posted : 27/01/2020 5:01 pm
Also (and admittedly this wan’t part of my original spec) it needs to be cheap enough that I can buy a 2 or 3 for making different types of tea at the same time, which the brewing basket is.
You're not a civil service IT contracts man are you? That's some serious mission creep from the first request! 🙂
Posted : 28/01/2020 8:15 am
These.
https://www.ebay.co.uk/itm/304-Stainless-Steel-Dual-Ear-Fine-Mesh-Filter-Tea-Infuser-Strainer-Home-Use/303224936119?hash=item46999d56b7:g:b6oAAOSwDLhdLDsk
And likely to fit your revised budgetary requirements. I use something similar that came with a posh mug from T2tea and it's brill, gets used about five times a day.
All the way from Shenzhen though so you'd better not be in a rush.
Posted : 28/01/2020 9:12 am
No idea about your question, but your thread title is a fine example of an otherwise tired genre. Good job!
Posted : 28/01/2020 9:36 am
You’re not a civil service IT contracts man are you? That’s some serious mission creep from the first request! 🙂
Haha! It's more that I couldn't imagine anyone spending more than a fiver to solve such a simple problem I guess, but that was naive.
The first suggestion fits the (un)specification perfectly and my local coffee roasters/tea blenders have them on their website so I'll go and see if they have them on their market stall.
Posted : 28/01/2020 9:52 am
😀 Agree it's tired but on this occasion thought it was acceptable.
Posted : 28/01/2020 9:53 am
https://www.amazon.co.uk/Finum-Brewing-Basket-Permanent-Filter/dp/B000I68NCS/blockquote >
Got one from the local blenders' market stall for a fiver and it's exactly what I was after. Will go back and get at least another one. Don't know why I faffed about for so long with the thing in my OP. Thanks!
Posted : 30/01/2020 6:37 pm
