Shower plumbing que...
[Closed] Shower plumbing question - Plumbing experts to the forum please.
Afternoon all.
Does such a shower exist which during the summer months creates hot water internally (i.e. an electric shower) and then during the winter uses hot water from the house hot water tank rather than using electricity?
Is such a thing possible or just plain madness?
Ta in advance.
Posted : 19/07/2014 12:45 pm
Can't really see the benefit (I do see what you are trying to do but savings will be absolutely marginal) and I'm pretty sure no one is going to be marketing this..
Posted : 19/07/2014 1:05 pm
We have a solid fuel rayburn which is on all of the time during the winter and produces constant hot water.
During the summer it is too hot to have the rayburn on and the only thing that we would really need hot water for is for the shower, hence the need for an electric shower. In the winter time it would be a waste of electricity though.
Pretty niche requirement I know.
Posted : 19/07/2014 2:03 pm
Install 2 showers?
Posted : 19/07/2014 2:23 pm
Fit a simple DIY 20 evacuated tube solar collector on your roof and enjoy hot solar water all summer? Cost would be about £700-800.
Here's how I did it: http://www.diynot.com/forums/viewtopic.php?p=1845563#1845563
Posted : 19/07/2014 3:48 pm
Does your Rayburn have a storage cylinder anywhere, I'd imagine if would. Could you not retrofit or install an electric Emersion heater? How do you get hot water in the summer normally?
Posted : 19/07/2014 5:17 pm
We do have an immersion heater but wouldn't it be a bit expensive to run?
Posted : 19/07/2014 6:15 pm
So rig the storage cylinder up to a collector and use the immersion to supplement the collector on cloudy days. You can even retrofit a coiled 10mm pipe inside the cylinder alongside the immersion. The solar collector works best if you've got a modern quick heating cylinder with a good debit from the coil and plenty of capacity - about 160 litres would be fine for three or four showers a day.
Posted : 19/07/2014 9:26 pm
You can get remote instant water heaters for showers. Just use a thermostatic shower and plumb the water heater in so you can by pass tank feed and use that when you want to.
Posted : 19/07/2014 9:30 pm
In laws have an electric shower over the bath and mixer taps as well so have the choice of an electric shower or one via the hot water.
Posted : 19/07/2014 10:32 pm
I have similar I use an electric shower in the summer and have a thermostatic shower for the winter.
Difficult to fit but the thermostatic shower taps are small compared to the electric shower box.
Posted : 19/07/2014 10:42 pm
Cheers all.
Posted : 20/07/2014 6:45 am
