Hi - as you probably know if you have an S3 when you open a type of file that you haven't opened before the phone asks which "program" to open it with and whether it should use that function just once or for all files of the same format. I accidentally set an App as the default route rather than once only for opening PDF files. BUT you have to buy the full version at £9.95 for it to display PDFs which I don't want to do really. I can't see how to reset my phone for this so that it asks me what App to use again.
Anyone got any ideas?
Go to settings -> Application Manager.
Find the app in question and select it.
Scroll down to Launch By Default.
Then select Clear defaults.
Next time you open the file it will ask you again.
Cheers Mr Morris you're a life saver (ever so slight exaggeration). Muchly appreciated.
