Had a Samsung TV and Home cinema with built in BluRay for a few years connected to each other with HDMI and Optical leads. Usually i can turn on both with the bluetooth remote and the audio automatically goes through the BluRay/Cinema setup but a few days ago this stopped and the home cinema setup only works if i go into the BluRay player settings and perform a factory reset. This then work perfectly for the rest of the day, but the next day it needs resetting again. After a couple of hours use it also displays FAN NG which i found out just means 'fan not good' and i can replace this part but it doesn't explain the loss of connection and constant need for resetting.
The cheapest replacement Home Cinema with built in BluRay is £199 so hoping there is a simple setting or part inside that will solve it but searching google leads to nothing.
Are there any experts out there?
get onto AV Forums 😉
