Running = calf stra...
[Closed] Running = calf strain
Having just started running (xc and gym only) the only real issue has been my calves that really ached at first. This started to die down, but today I picked up a calf strain halfway around a 12km loop, and had to limp/walk the way home. I was fully warmed up when it happened.
Any tips for avoiding such injuries? Does compression clothing help?
Posted : 16/12/2012 5:02 pm
The obvious one is stretching. Loads of good stretches on youtube. Maybe look at doing some drills for strengthening and improving technique. You could always get a deep tissue massage in your calves. Nice. ๐Ÿ™‚
Posted : 16/12/2012 5:19 pm
If you over pronate you are likely to suffer from this. Have you got the correct shoes fitted?
Posted : 16/12/2012 5:20 pm
In answer to your two questions - Not really, and probably not really.
Which isn't really that helpful. The important part to take away is the 'just started running' bit, ultimately this probably means a fair few aches / pains and strains as your body gets use to running and you get use to the feedback signals your body gives.
Posted : 16/12/2012 5:22 pm
What Ian said.
Classic problem for cyclists getting into running.
Posted : 16/12/2012 5:25 pm
Too much too soon.
Sure your heart, lungs and brain may be fine but it will take a while to adapt.
You did too much too soon and your calf compensated by doing too much work when something else fatigued.
Rest, heal and take it slow or you will blow out again.
Been there myself. Had to grind teeth and run 3 miles 3 times a week and then 10% increase each week.
It sucks but you need to adapt or risk injury.
Fuel your body well too and check your flexibility.
Injuries happen. Compression clothing isnt really going to prevent injuries.
Posted : 16/12/2012 5:34 pm
Thanks folks. Flexibility is fine, and I do stretch regularly.
The short answer is: I don't know. When I was researching the shoes, I read in several places that over or under pronation is not so relevant to trail/xc running, due to the uneven nature of the surfaces.
I suspect it is more to do with too much too soon, as others have mentioned, although I managed over 11km last week with no issues whatsoever. I guess it could be the combination of too much over a short period.
Posted : 16/12/2012 5:37 pm
That's running for you. I generally do 30-50 miles a week but picked ups very similiar injury in June on a 10k easy run. Just happens, don't run on an injury and you'll be fine.
Posted : 18/12/2012 12:01 am
Go barefoot.
Posted : 18/12/2012 12:07 am
Cheers Sean. It feels a bit better today, so I don't think it's serious. May have to lay off the running and biking for a few more days though.
Posted : 18/12/2012 12:08 am
Go barefoot.
No thanks: I prefer to keep sharp objects and animal faeces away from my feet.
Posted : 18/12/2012 12:09 am
 rs
Go barefoot.
trying that pish is what injured my calf, would not recommend it, especially in this situation.
Posted : 18/12/2012 12:25 am
