Router problems for...
[Closed] Router problems for the hive mind....
Ok, so router is working fine with the laptop - internet not slow (well, it is - but no slower than usual), uploads HD video to Youtube fine etc.
However, both my phone and the daughters phone won't connect. They see it, the IP address is fine, WEP key is fine, and they do actually connect, but then drop out straight away stating poor network connection.
Any ideas?
Posted : 24/02/2013 10:11 am
try a different channel?
Posted : 24/02/2013 10:12 am
try a different channel ?
๐Ÿ˜ณ
Posted : 24/02/2013 10:16 am
Didn't even know there were different channels ๐Ÿ˜ณ
It's only a crappy free Thomson one, due to a power surge blowing the usual one.
Goes to investigate
Posted : 24/02/2013 10:19 am
+1 for different channel
I started having WIFI connection problems a couple of weeks ago and it had been fine and changing it to a different channel seems to have solved it - it had been set to Auto.
Try using Inssider http://www.metageek.net/products/inssider/ to locate part of the spectrum that is vacant/less densely used - I have set mine to channel 13
Posted : 24/02/2013 10:23 am
Turn it off and on again. My ageing netgear needs a kick every now and again.
Posted : 24/02/2013 10:25 am
They're reasonable router's normally. Have you restarted the router? Perhaps consider moving to wpa or wpa2. It's more secure. Perhaps double check that wireless password.
Posted : 24/02/2013 10:26 am
Stoner has it, chances are it's channels for some reason smart phones seem more sensitive to them.
http://www.plus.net/support/broadband/hardware/thomson_wireless.shtml
Posted : 24/02/2013 10:29 am
Adsl routers are so ridiculously cheap these days it's hardly worth the effort of trying to work it out. Just get a new one.
Posted : 24/02/2013 10:41 am
Sorted - thanks guys
Posted : 24/02/2013 10:42 am
Good idea, keep buying new ones until you get one that uses a different channel. Far easier.
Posted : 24/02/2013 10:43 am
[b]allthegear[/b] - Member
If ever there was a more apt username with that comment
Posted : 24/02/2013 12:32 pm
