Only just signed up to this so still feeling my way round it. I have found an existing route which i want to do in reverse. I have worked out how to reverse it but it still shows the cuesheet in the original way by the looks of it, so how do i reverse that? According to google it says the cuesheet is automatically reversed when you do the route but it looks the same to me. Any help/advice appreciated?
Not something I've had to play with but have you saved the reverse direction as a new route? Then try the cue-sheet from the newly saved route.
As above save as a new route
Used ridewithgps for a few years now and it works but nothing is obvious
As to ย cue sheets well worth printing (old school) and then "walking" thru the route I usually use the hybrid map option ie roads and satellite to do this - some of the instructions will make no sense and can be a bit random depending on how whoever created the route did it also you can pick out and add to the cue sheet obvious features that mean missed ย a turn
Not being negative and the gpx export works if can find it
