Replacement keys fo...
[Closed] Replacement keys for VAG group car.
54 plate passat.
One key which got temporarily list earlier this week.
I'm assuming it'll be cheaper to buy a new car than to get one from a main dealer, so what's the most cost effective way of getting a second key/alarm remote sorted.
Posted : 23/01/2014 10:36 pm
Speak to a key cutting place, some can code a key form your old one.
Failing that, it'll be a couple of hundred quid from a dealer for a new key 😯
Posted : 23/01/2014 10:46 pm
I added remote central locking to my Fiances Polo - a used remote key was about £15, including a blank blade, cuting was about £20 but it was right on my doorstep, could have got it cheaper if I'd shopped around. A blank transponder chip was about a tenner. Provided you have at least one working key you can program a blank transponder by having the new key in the door while you start the engine with the old one (or something along those lines).
Posted : 24/01/2014 12:02 am
Go around and ask your neighbours?
Posted : 24/01/2014 7:18 am
 tomd
I had to replace the key on a 54 VW T5 a few years back. The only place i could get it was through a main dealer. From memory the physical key was something like £120 and it was £60 to program it in, so £200ish.
Posted : 24/01/2014 8:29 am
I have just been quoted £80 by my friendly independent and £144 by the main dealer for VAG. Unfortunately, the friendly independent is a way away and will need both keys, rendering it somewhat difficult to collect the car in the evening.
Posted : 24/01/2014 9:55 am
I had a mobile locksmith and cut two keys for my 54 plate T5. If you can do without the remote, is you're capable of putting a key in a lock and turning it, it's about 60 quid a key. Remote is about a ton.
Posted : 24/01/2014 10:03 am
You should be able to key it for less if hunt around ebay. You need two parts: 1) a key blank - ebay £4. Then get this cut to match existing key. I go to Bury St Edmunds market who charge £5 and do a great job. Then you want the electronics. For this buy a second hand key fob off ebay - about £15-20. You need to reprogramme the key fob to match your cars central locking and immobiliser. The lockng is easy:
[url= http://www.myturbodiesel.com/wiki/key-remote-replacement-troubleshooting-mk4-jetta-golf-new-beetle-passat/ ]This site[/url] gives info on the immobiliser.
Posted : 24/01/2014 10:36 am
