Having problems with Cricut Design Space so thought I would remove and install again.
Once it’s reinstalled I don’t have to sign in again. This makes me think that it’s not totally going away.
I remove it by right clicking and clicking on uninstall using clean my Mac.
Is my thinking correct?
I use Appcleaner; http://freemacsoft.net/appcleaner/
it shows you all the associated files that it is removing.
Check your preferences folder and delete the prefs for the app - they won't have been deleted when you deleted the application.
Check your preferences folder and delete the prefs for the app – they won’t have been deleted when you deleted the application.
This - might be in the hidden library...
Hold the Option key on your keyboard, and click the Go menu at the top of the screen. With the Go menu open, you'll notice that pressing and releasing Option will display or hide the Library choice in this menu. Select Library from the Go menu (while holding down Option) to access the hidden folder.
^^ That too 🙂
