I would like to extend the reach of the broadband wireless signal in the house. I bought some powerline extenders but then realised that I don't want to have to plug in to the receiving end via cable so I'm looking for a wireless signal in the receiving room(s).
I've seen this [url= http://www.amazon.co.uk/TP-Link-TL-WPA281KIT-Wireless-Powerline-Extender/dp/B0067GS29W/ref=pd_bxgy_computers_text_y#productDetails ]TP-Link-TL-WPA281KIT-Wireless-Powerline-Extender[/url]that does, I think, what I want but always good to have recommendations.
lol! I did the exact same as you, bought the ones to extend plug in range, not wireless. Still to buy the proper ones yet.
[url= http://www.amazon.co.uk/Netgear-WN3000RP-Universal-Wi-Fi-Extender/dp/B0055Y6PUA ]this thing[/url]
Works perfect in my house. Picks up weak WiFi signal, amplifies and transmits it
I bought the exact same one as linked in the OP.
Works perfectly.
If you use the one in the first post, check both sockets are on the same circuit
Mine aren't ?
Well, they are operated by different switches in the consumer unit anyway.
I've noticed that there is a later version of the product I linked to:-
[url= http://www.amazon.co.uk/TP-Link-TL-WPA281KIT-Powerline-Extender-Ethernet/dp/B00ECBRGW8/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=ELCK3NOA5GFF&coliid=I3OY8SRVJDR4EM ]TP-Link-TL-WPA281KIT-Powerline-Extender-Ethernet v3[/url]
and
[url= http://www.amazon.co.uk/TP-Link-TL-WPA4220KIT-Powerline-Extender-Starter/dp/B00DHB2T44/ref=wl_it_dp_o_pd_nS_nC?ie=UTF8&colid=ELCK3NOA5GFF&coliid=I3MIM4J4DIEDV ]TP-Link-TL-WPA4220KIT-Powerline-Extender-Starter[/url]
EDIT: yes the one you linked to is fine. I shave the cheaper cable-cable ones but these are ok given the low price.
Got a [url= http://www.mobilefun.co.uk/huawei-ws320-wifi-repeater-booster-white-p39539.htm ]Huawei ws320[/url] Works well.
nealglover - Member
Mine aren't ?Well, they are operated by different switches in the consumer unit anyway
I was under the impression that they didn't work well across breakers, but further reading suggests they do...
I tried that huawei one before I got the netgear one, couldn't get it to work for long, but maybe that's just me. Difference with both of those is that they're not using your cabling to transmit, they only boost a weak WiFi signal. My router is in the front of the house, WiFi very poor in rear of house, but with booster installed its perfect, and I also get usable WiFi 20 metres down my garden
sorry to drag up an old thread, but does anyone know if these TP-Links will work through extension leads?
Devolo are the best I've used - http://www.scan.co.uk/products/devolo-dlan-500-wifi-starter-kit-duo-powerline
Everything is joined up in the Consumer unit - won't make a lot of difference as the switches aren't RF filters.
Perfectly.
I have the TP-Link happily working on a multiway pluq with the laptop, printers, phone and router, all at the end of a 5m cable.
ta.
Funny, I'm having problems with those TP LInk ones - I'm not sure whether it's because the sender and receiver internet are both on extension cables, or because they are somehow on different circuits (because of solar power panel? Because power done differently in extension to original bit?).
I understood that the extension cables would only be a problem if they have anti-lightning thingies.
How big are these mansions you guys live in, as my standard BT jobby works perfectly well from one end of ours to the other - and that's the best part of 20yds and two storeys plus 3ft stone walls.
