Plumbing - external...
[Closed] Plumbing - external sealant for slight leaks?
My wife's at home on her own, the toilet inlet is leaking at the valve joint.
There are external leak seal products, are they likely to help in this situation? Any recommendations?
Posted : 06/05/2015 10:37 am
It's under mains pressure so I think you may be better off replacing the joint ๐Ÿ™
IANAP
Posted : 06/05/2015 10:39 am
Self amalgamating tape?
Posted : 06/05/2015 10:40 am
Ok but I'm away from home, and my wife has to do this. I doubt she's up for replacing joints.
I'd be interested to know if anyone's used this:
http://www.diy.com/departments/sentinel-seal-x-leak-sealer-50ml/262261_BQ.prd?gclid=CMLiidnprMUCFUyWtAodpGMAwg&ecamp=SEAPLA262261_BQ&ef_id=VQ-lYAAAAJByGDzL:20150506094157:s
Posted : 06/05/2015 10:41 am
Drain cistern. Isolator in supply or main stopcock. Use bucket to flush loo until fixed.
Fernox LS-X does work sometimes, but why bother risking it.
Posted : 06/05/2015 10:42 am
what midlifecrashes says - just turn the supply off - there should be a quarter turn valve within a foot or so of the inlet to the cistern.
Posted : 06/05/2015 10:43 am
Yep, just turn off the isolating valve when not in use until her hero returns.
plumbers putty... [img] [/img] should be cheap and readily available at a plumbers merchant or local diy, similar to the b&Q stuff probably. As a temporary fix whats not to lose - then fix it properly on your return
Posted : 06/05/2015 10:46 am
^ this. The silicone version might be easier for her to stretch around the joint.
Service valve on the inlet pipe? Probably easier to encapsulate the whole valve starting and finishing a good inch along the pipe either side.
edit: I did wonder which side of the valve. If the toilet side just turn off and put a bucket underneath or wrap in a towel.
Posted : 06/05/2015 10:47 am
It's the toilet side, apparently. Problem is the pipe goes straight down into the floor.
[url= https://farm8.staticflickr.com/7774/17202801299_08d2c102eb_z.jp g" target="_blank">https://farm8.staticflickr.com/7774/17202801299_08d2c102eb_z.jp g"/> [/img][/url][url= https://flic.kr/p/sd9Rup ]toilet[/url] by [url= https://www.flickr.com/people/11569254@N06/ ]molgrips[/url], on Flickr
Posted : 06/05/2015 10:51 am
Putty for a quick fix, but I'd expect to replace it when you get home.
Tape if you can get a tight pull all around the joint, and don't spare the layers ๐Ÿ™‚ - but also I'd replace. Any mains pressure joints need proper sorting or they'll go again when you're all away for 2 weeks.
Posted : 06/05/2015 10:53 am
Any chance she could just nip it up half a flat? Might be all it needs.
She tried nipping it up, to no avail.
Is the valve in that picture a quarter turn one? I told her to set the slot horizontal..
Posted : 06/05/2015 10:54 am
Just turn the valve, flush it and see if it refills?
Posted : 06/05/2015 10:59 am
yeah just turn the valve slot so it's across the direction of flow - ie horizontal. Wrap some towels round and keep changing them as there will only be a little bit of water up to the spout inside the cistern.
Posted : 06/05/2015 11:03 am
Seems that turning the valve horizontal has indeed stopped the flow. Thanks folks. I will re-do the joints when I get home.
Posted : 06/05/2015 11:11 am
