Plumbing a washing ...
[Closed] Plumbing a washing machine into the garage.
Before you all start about ringing a plumber I am prefectly competent at plumbing.
I am moving a washing machine from my parents kitchen into their garage.
I would normally always fit a U bend to stop the drain smells running back. In the garage the waste pipe will exit through the exterior wall into an open drain with an air gap so I shouldn't need a U bend in the waste pipe.
I am thinking of avoiding a U bend in the waste pipe just incase it freezes. The garage is detached and fairly draughty. I will insulate and lag all feed pipes.
Appreciate any suggestions.
Posted : 24/11/2011 1:13 pm
Pressure ok? Garage sounds like it might get cold.. Good idea to have water freezing in the machine?
Posted : 24/11/2011 1:16 pm
Pressure is fine, not sure how that is relevant.
I am probably worrying about nothing.
It is worth mentioning that they live in Exeter in Devon in the city. I can't beleive that the residual water in the machine will ever freeze but I did think that the U bend attached to the exterior wall may cause problems.
Posted : 24/11/2011 1:54 pm
Sounds like you plan to run wastewater into a storm water drain. Don't, there's prolly some regulations about this.
Plus all the stuff about freezing.
Posted : 24/11/2011 1:59 pm
Drain is a sewage / waste water drain not storm water. Their used to be a sink in the garage at some point many many years ago.
Posted : 24/11/2011 2:07 pm
Yep, if it's just a washer, I can't see a big deal, but then I put a U bend in mine (unheated utility) with an eye on creepy crawlies climbing in rather than smells. Mine has a drop from the end into an older drain gully too.
Posted : 24/11/2011 2:50 pm
Mines in the garage exactly as you describe; pipes froze solid during the extended cold spell that we had last year, despite more lagging than an iphone 4 entering text on STW. Proper proper pain in the arse, it was.
Posted : 24/11/2011 3:02 pm
